MPC5002 Fusing Sleeve Failed
  • copier tech
    • 8101
    [Misc] MPC5002 Fusing Sleeve Failed
    Got a MPC5502 with a fuser sleeve that appears to have melted & peeling away, it's almost turned sticky! not near it's PM life, m/c is only 6 months old too.I've ordered D144 4046 I believe this is the latest p/n I'm hoping this version has been modified?
  • coolbeer
    • Jul 2011
    • 100
    Re: MPC5002 Fusing Sleeve Failed
    Have seen the same many times, suspect poor manufacture / possibly customer not using correct settings for type of media used.
    • Smee
      • Aug 2009
      • 178
      Yep....pretty common....!
      • rsyarcia
        Hair Straightener Tech
        • 711
        we have the same problem...
        Nobody is perfect..
        • copier tech
          • 8101
          Has anyone had the later p/n version fail early?
          D144 4046
          • tjvincent
            • 280
            The latest part numbers are much better, but make sure you update firmware before replacing, lots of fuser settings in the updates.
