MPC4503
  • GeorgeBest
    • Jul 2009
    • 526
    MPC4503
    Hi,
    Customer uses LDAP for scanning on this machine.
    He complaines that he must make to many actions for choosing a user when making a scan.
    Is there a possibility to shorten this, for example, to make a shortcut/icon in the scanner display the same way
    when you choose directly from the adresbook ?
    I've checked but I don't think LDAP works this way . . .
    anyone ?
    Thanks in advance
  • Eric1968
    • 2458
    Re: MPC4503
    I also have a few customers that use LDAP, and they also complain about this. Easiest way is to program every email adress in the adress book. I know, it can be a lot of work when the amount of adresses is large. You can export the adress book to a .CSV-file using Smart Device Monitor and store this file on the server in the unfortunate event that the HDD of the machine crashes.
    • Zaxxon
      • 608
      Use LDAP to look up the mail adress, then save it to the adressbook.
      Make backup from webinterface when done.
      Upload the backup to the next machine if needed.
      Sent from my iPad using Tapatalk
      Please start you post with brand, model, problem.
        • 23009
        Re: MPC4503
        One of the IT people that I see regularly insists that the Ricoh products he's had in the past "downloads" the LDAP information to the machine's addressbook. After multiple attempts to explain this I've given up.
        For your benefit, an LDAP search is a one-time snapshot of a very narrow search criterion. It does not "download" anything. The number of steps required doesn't change to do a search. It is always more convenient to select a one-touch addressbook entry, than to do an LDAP search. Yes, there is some setup required. If you or your installer cannot spend the time to enter the data, it can be easily explained to an enduser, or maybe an enthusiastic salesman to enter some data. =^..^=
        • heeks
          • Jun 2012
          • 19
          Re: MPC4503
          Hi guys,
          First of all, sorry for answering on that old topic but I have the exact same question.
          My users complains that searching via LDAP is really annoying : you have to click on "Scanner/Specify.../Search.../Ldap/Name" then type some letters etc...
          With the SOPs of 2017 is there any chance that we could create a shortcut on the home screen for example ?
          Thanks for your answers !
            • 37544
            Re: MPC4503
            Originally posted by heeks
            Hi guys,
            Then start a new thread or get ignored.
