Ricoh MP 2510 Scanner Twain Driver Problem
  • faraz_afaq
    • Apr 2013
    • 27
    [Error Code] Ricoh MP 2510 Scanner Twain Driver Problem
    Hy guys,
    How are you i hope u will be fine, guys i m facing problem of Network Twain Driver. I have a domain environment and i installed network twain driver of ricoh mp 2510 when i import the scan files through ( Adobe Photoshop, AcdSee, Microsoft Clip Organizer E.g) or other software then one eror appear on screen "1230" cannot find the scanner. I have been change the printer kit. I have been disable the antivirus and firewall but no luck. Kindly let me know if you have any experience of that type.
    Faraz
  • qbert69
    • Mar 2013
    • 1152
    Re: Ricoh MP 2510 Scanner Twain Driver Problem
    Possibly This???
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
      • 37494
      Software you are using might not be compatible with TWAIN scanning. Try installing Irfanview. The other possibility is that your firewall is blocking the software from connecting to the network device. With many firewall softwares, the user does not always read the warning message that pops up the first time a software tries to access a network device. They just click block. After that, no more messages. You have to go into the firewall settings to reopen the port to the software. I have had a number of customers with McAfee firewall block TCP/IP printing.
      • craigchowles
        Try using the network setup tool that loads with the twain driver. There might be more than 1 machine on the network so the driver doesn't know which machine to pick.
        • rthonpm
          • Aug 2007
          • 2854
          Is there a reason for choosing TWAIN over a more reliable method like SMB or scan to email? Outside of USB scanning, TWAIN is really all but dead since firewalls and other network security tools have become more sophisticated.
          --sent from my BlackBerry using the Android app
            • 37494
            I have some customers, medical offices and attorneys, who use software that utilize TWAIN drivers from within the software in order to import documents directly to client/patient accounts. Much faster than scanning to folder or email, then locating the file and importing to the software.
            • rthonpm
              • Aug 2007
              • 2854
              This is the first logical explanation I've heard for using TWAIN in a long time...
