mpc 2800 jamming in duplex
  • rhe
    • Feb 2013
    • 51
    [Jamming] mpc 2800 jamming in duplex
    having jam problem in duplex behind tranfer roller unit ,anyone has experienced this
    thanks
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: mpc 2800 jamming in duplex
    Main mounting hindges holding the tranfer unit in position may be cracked or broken at the pivit point.
    Disassemble tranfer unit away from duplex unit to locate the problem.
    SMC report should show you where further problems exist.
    HTH
    • salmandol
      • Mar 2009
      • 107
      mpc 4500 has a set of rollers in back of transfer unit, the spring hooks that holds it place break. not sure if the mpc 2800 has the same. Honestly never experienced it in mpc 2800 but it is very common in mpc4500.
      • mntech
        • Aug 2010
        • 250
        try some fresh paper, sometimes after going through the fuser, paper curl could cause the paper to not want to follow the proper path
        • Max
          • Oct 2011
          • 561
          check the exit guide above the fuse unit,it is probably warped from the heat. Unfortunately you need to take it out and strip it to see the damage. Had it many many times.The guide d0294424 and i believe there is a modified sensor aw010127
          • Bantams
            • Jun 2012
            • 603
            Also could be one of the white plastic scrappers from the top of the duplex unit as fallen off and landed under the transfer unit.
            • Debs1964
              • Oct 2010
              • 1693
              Yes, I've had that, and they get stuck in the most inaccessible areas
              There are 10 types of people in this world, those who understand binary maths and those who don't
              • Counsel
                • Aug 2011
                • 529
                What are the jam codes, there is a TSB for J064 and J067 jams for a warped guide. Its also not uncommon for the transfer deck rear hinge to break this would probably be noticable as the deck pretty much flops out of place when that happens unless its only cracked and not completly off. They added a metal stay to the transfer deck for that problem.
                I would post the jam codes and check the transfer deck is not broken. I believe there is also a couple one way gears on the rear side that may be slipping so its not transporting as it should.
