MPC2500 color problem
  • cbr600
    • Jun 2010
    • 71
    Maybe can some one help me with this problem, the text get a a double background only on colors, i am suspecting the laser but...tees.jpg
  • AndyPerkins
    • 13
    Re: MPC2500 color problem
    Does colour registration set up?
    • mikadonovan
      • May 2008
      • 2931
      Looks like you need to run line position adjustment. Start with the coarse and work your way to the fine adjustment.
      NEVER ASSUME ANYTHING
      • Eric1968
        • 2458
        Check the line positioning result to see what went wrong during the latest adjustment. I don't think you can correct this by using SP2-111-003 and SP2-111-001. Don't think the machine can correct this by itself because deviation is too large. Also check this post :
        http://www.copytechnet.com/forums/sh...489#post400489
        • ricmartinho
          • 142
          Also clean the ID Sensors
          • ruben
            The New Guy
            • Oct 2012
            • 1203
            Originally posted by cbr600
            Maybe can some one help me with this problem, the text get a a double background only on colors, i am suspecting the laser but...[ATTACH=CONFIG]23859[/ATTACH]
            What have you done so far?
            • JustManuals
              • Jan 2006
              • 9838
              Paul@justmanuals.com
              • cbr600
                • Jun 2010
                • 71
                Color registration is working,auto color is not working.i cleaned the id sensors i will try line position adj tomorrow
                • Counsel
                  • Aug 2011
                  • 529
                  I would check the post eric mentioned. Clean the ID sensors, check the PMs on the PCUs make sure they arent hard to turn, and check your transfer belt for any binding. Eliminate mechanical problems like the belt and drums as well as checking your alignment SPs. You may also try updating firmware if your having issues with ACC failing. Thats where i would start, i have had a few throw off alignment because drum blades were dry and dragging one pcu. I can usually tell if its a drum by printing off the color gradient pattern like acc does you can tell if they all look straight except one is moved up/down or sideways then that drum may be dragging. if nothings lined up i would lean towards the xfer belt unit depending on what the total page count is on the ITB, a machine over 600-700,000 pages has pretty much run its course so EM parts like that can go out.
                  • freedomseahorse
                    • Mar 2012
                    • 37
                    Doing the line positioning mode a,mode b and mode c.after that doing colour registration.lastly doing auto colour calibration.
                    IF your
                    colour registration and auto colour calibration not working,check your controller board have connect properly or not......
                    • cbr600
                      • Jun 2010
                      • 71
                      Problem soved:
                      1. cleaned id sensors
                      2. force pos adj c
                      3.force pos adj a
                      4.color registration
                      Auto color calib is not working copy/printer but the image quality is ok
                      Thank you for ur posts.
                      • Eric1968
                        • 2458
                        If the Auto Calibration is not working, I think the problem will be back soon.
                          • 37514
                          Auto color calibration has more to do with image density than line position. Make sure that the optics are clean and that there aren't any PCUs or development units that are due to be replaced.
