Afcio mpc4500 sc860
  • Valintine
    • Jan 2012
    • 147
    Afcio mpc4500 sc860
    Hello
    I have a machine with a sc860 code. I can get into service mode. Can I replace the hard drive and format it in service mode or do I have to do a firmware update like in the Toshiba's?
    • 37525
    Re: Afcio mpc4500 sc860
    You can try just formatting with SP 5832. If that does not work, replace the HDD. Be sure to let the customer know that the address book and anything they have saved in the Document Server will be lost if it hasn't already been lost.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • Valintine
        • Jan 2012
        • 147
        I tried reformatting the hard drive and still get the same code. I have bought a new hdd and installed it. Do I just run the format or do I have to do a firmware update?
        • sandmanmac
          • 3981
          This machine has 2 HDD's, so you know that they must be a 'matched set'? You'll likely have to replace them both, unless you have access to the exact same size, make, speed, etc. HDD.
          Any size will do, as long as they're 80Gb minimum.
          They should automatically format, but otherwise, yes, Format, and then download 'stamp data', then reprogram all scan destinations, etc.
          Happy "Valentine's" day!
            • 37525
            Hopefully it is not like the Aficio 2232c/2238c which required a preformatted raid set. You had to order from Ricoh or a used parts provider.
            • sandmanmac
              • 3981
              No. I've replaced these with off the rack IDE's
              • VITAL
                • Nov 2013
                • 2
                I guess Ricoh uses Raid controller in these machine, so it supposed to replace HDD as a HDD unit.
                From service manual:
                When installing a new HDD unit
                1. Turn the main power switch on. The disk is automatically formatted.
                2. Install the stamp data using "SP5853".
                3. Switch the machine off and on to enable the fixed stamps for use.
                • Valintine
                  • Jan 2012
                  • 147
                  I just bought two matching hard drives and replaced. When I turned the machine on it said to press restart after it finished. I did so and still get a hard drive failure. I tried downloading the stamp data and I get a message that there is no data. Any ideas?
                  Thank you
                  • sandmanmac
                    • 3981
                    Thank you
                    There's no mention that you ran SP5832 (format all) as discussed above, then download stamp data
                    • Tonerbomb
                      AutoMajical Resolutionist
                      • Feb 2005
                      • 2589
                      Thank you
                      If you can access SP mode, you need to see if there are additional codes logged for the problems you are seeing. Stamp data from sp 5853 comes from the controller, if there is "no data" your controller or NVRAM may be hosed(BAD)................
                      Mystic Crystal Revelations
                        • 37525
                        You may have a problem with the cables going to the drives.
                        • Valintine
                          • Jan 2012
                          • 147
                          I thought the format worked yesterday but today when I tried it again it failed. I have tried reseating the nvram and when I check the sc history there are a number of different ones all pointing at the hard drive
                          • Valintine
                            • Jan 2012
                            • 147
                            I just made it back to this. I did run the full format and I get a message that it failed
                            • sandmanmac
                              • 3981
                              In most cases, SC's can point to any number of different issues.
                              However, in this case, every bit of information /experience I have, ALL points to a hard drive failure.
                              I would look at TB's suggestion of seeing if there are any other SC's being logged, as well as Slim's suggestion to check /replace the cables (and plug connectors) to the HDD,
