Afcio mpc4500 sc860
  • anothertech
    • 1771
    #16
    Re: Afcio mpc4500 sc860
    Have you formatted the drives with your laptop yet? If not, connect them one at a time to your computer with an external hard drive enclosure and format them NTFS, then try them in the copier.
    • Richariri
      • Dec 2013
      • 163
      #17
      This could be completely unrelated but I have a feeling it could be.
      We had a similar issue on an MP5500 where it would freeze and show memory failure whenever we tried to do a copy of anything above 1 quantity.
      We replace the hard drive, formatted both on computer and in SP mode and the fault cleared for a half hour or so.
      but it kept coming back... we eventually got a ricoh tech out who knows about the fault and says it's on an internal memo (thanks ricoh)
      ended up replacing Dimm cards and refitting the hdd, turned out to be a faulty BICU board after all that.
      as I said, could be completely different. Now that I've written it down it sure doesn't sound the same.
      who knows? I don't!
