MPW2401 SC899 when scanning
  • Ballas
    • Nov 2013
    • 29
    [Error Code] MPW2401 SC899 when scanning
    Hi Guys
    Has anybody had SC899 on a MPW2401 when scanning? The machine copy's fine, but gives code when scan to folder or mail?
  • Vollegaaz
    • 73
    Re: MPW2401 SC899 when scanning
    update the firmware to version 6.16 and tadaaaa....
    • Ballas
      • Nov 2013
      • 29
      Only this time no tadaaaaaa? Firmware was the first thing I tried, and SC899 is not in the latest version Service Manual, only a RTB8A witch states do the Firmware. Anybody else maybe had this problem?
      • Vollegaaz
        • 73
        Well, in that case, are you sure that your scan settings are correct? (windows logon etc...) was a known issue on the 2400, when the machine fails 3 times to login during scanning sc899 occoured.
        • Ballas
          • Nov 2013
          • 29
          Hi Vollegaaz
          Yes there is no authentication set.
          • Ballas
            • Nov 2013
            • 29
            Also Vollegaas, are you quite sure about the firmware version (6.16) The RICOH RTB states version 9.61 should be done?
            • Vollegaaz
              • 73
              no sorry for that...that should be for the Mpw2400, my mistake. Witch OS, no authentication will not work since W7...
                • 37538
                If I remember correctly, Windows 7 requires a valid user name and password for scan to SMB. There is a Custom/Special firmware available for Windows 8 and Server 2012. It wasn't listed on TSRC, but I checked rfg-esource and it was available there.
