toner problem in mp5500
  • vargue
    • Oct 2011
    • 404
    [Misc] toner problem in mp5500
    hi shapes .customer call me to get ride of light image .and developer exhausted .i changed developer type 14 it's expensive but worked like a grenade.but after about 5 days customer call me again about light image .i make forced toner supply and become sharp and checked bottle rotate and tank already throw toner.and also checked vsg/ vsp reading right.what is make toner stop throwing with continuity. any suggest
  • Iowatech
    Not a service manager
    • 3930
    Re: toner problem in mp5500
    If that machine is making too few prints, you might try adjusting the toner feed time. It is somewhere in SP2, close to the forced toner feed setting you used, I don't remember the exact SP mode, sorry about that.
    On older models of that chassis, the value of that SP mode needed to be reduced to make toner feed time longer to make up for the lack of expected prints. I'm fairly certain that if your machine isn't being used enough that should work for your machine, too.
    • Herrmann
      • Jan 2006
      • 792
      do forced toner supply 2 times and then, if the developer is not too old, do 2801-001 again. worked for me.
      hope this helps
      If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
      • Counsel
        • Aug 2011
        • 529
        When you replaced developer did you clean the toner holes. When you seperate the toner casing and developer unit and open it like a lid there are holes in the bottom of the toner casing where toner comes through, make sure those are cleaned so they are all allowing toner to come through. Also check the plastic mylars in the toner seperation. At the front of the toner unit there are 3 screws to remove the seperation thing a lot of times the mylars come off and this part needs to be replaced.
        Also check when the last time a drum was replaced, these go for a pretty long time so many times the developer, blade, and corona are replaced and no one checks the drum time. If all those check out then I would also try the above suggestions as well. I only suggest these because if it is a problem in the hopper or drum doing the above posts would probably only help for a short time.
        • vargue
          • Oct 2011
          • 404
          this first thing i do it. that detect that holes throw toner inside developer tank.of course. toner line in machine run. today i checked developer tank.it's run perfect.and bottle rotate in sp mode. vsg4.02 vsp0.12 pwm 51 .and toner .but on of my friends tell me to reset counters. i maked common reset. and we will wait and see this fuck thread revealed after 2k.
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            What are your Vt and Vref numbers???
            Mystic Crystal Revelations
            • Counsel
              • Aug 2011
              • 529
              Did you initialize the developer the sp 2801-001 ? I assume you did but figure its worth asking.
              • fshead
                • 2378
                developer type 14??
                as i remember it uses the same as the 1060 which is type 24 dev
                • fshead
                  • 2378
                  very common as they fall off and clog the opening...
                  in a pinch i ve re-glued them back in place..
