ricoh mpc 2500 drums
  • mrgene
    • 53
    Could someone please explain:
    If you can take a black drum unit and put a color dv on it and its slides in. Why cant you take a color unit install a black dv and it will not work , is there some way to make this work ?
  • Eric1968
    • 2458
    Re: ricoh mpc 2500 drums
    Why are you working with color drum units? They're 3 times more expensive than the black ones.
    • mrgene
      • 53
      because I have around 20 good used color units ( I just junked 6 mpc 2000 for spare parts)
      • Blizzoo
        • Aug 2013
        • 608
        I didn't work on a Ricoh Color before,are you sure there is a good concentration of developer in?
        • Eric1968
          • 2458
          The only difference is the connector on the drum unit. So it should work...
