MP5500 Fuser
  • tinfox
    • 317
    MP5500 Fuser
    Hi All y'all,
    I bought a new fuser for a 5500. Brand new. The old fuser was making dark, normal, looking blacks. On the new one the blacks look a bit faded, like the machine wants a dev change. Also the new fuser has broken its fuser gear twice in the last 10 months.
    This account makes maybe 90K a year.
  • Eric1968
    • 2458
    Re: MP5500 Fuser
    Why did you change the whole Fusing Unit when the old unit is working ok???
    • tinfox
      • 317
      Re: MP5500 Fuser
      The web was almost up and there was a line starting on the upper fuser roller. There was a fuser on ebay for $250 so that's why. I'm lazy
      • Vollegaaz
        • 73
        Re: MP5500 Fuser
        ow...okay!
        • ruud.janssens
          Re: MP5500 Fuser
          Originally posted by Vollegaaz
          ow...okay!
          Hello, did you check the nip of the fuser? NIP is the contact between the Hotroller and Pressure roller. probeably is't to thight thats why the gear broke. and chanching the web is much cheaper. fuser is almost lifetime ( 9 milj.)
          • tinfox
            • 317
            Re: MP5500 Fuser
            Is that something you adjust via springs? I'll check the manual when I get back to the office.
            • Debs1964
              • Oct 2010
              • 1693
              Re: MP5500 Fuser
              Yes
              There are 10 types of people in this world, those who understand binary maths and those who don't
              • Counsel
                • Aug 2011
                • 529
                Re: MP5500 Fuser
                All i got from the that was Problem Fuser from Ebay. Like Debs said it probably needs adjustment for your machine who knows where it came from or what was wrong with it before hand. If you still have the original fuser couldn't you just transfer the web over to it, even if the hot roller had a line starting i have seen everything from lines to gunk to coating peeling right off and still fusing normally looks can be deceiving sometimes.
                • fshead
                  • 2376
                  Re: MP5500 Fuser
                  CLASIC QUOTE..............reminds me when i use to pick up ricoh ricoh serviced accounts and find brand new pcu inside the cabinet that they were too lazy to pop in.....
                  • Counsel
                    • Aug 2011
                    • 529
                    Re: MP5500 Fuser
                    Just to make sure you got the right fuser too, im pretty sure the MP6000 fusers will fit in the machine and look the same but they only have 2 heating lamps instead of 3. I would think if it was wrong you would get an sc code but hey easy to check.
                    • fshead
                      • 2376
                      Re: MP5500 Fuser
                      Originally posted by Debs1964
                      Yes
                      not sure for europe but here in ny i dont remember any adjustment for pressure outside of the option of
                      which hole the spring goes to on the lower roller lift arm..i leave them on outside spring..blown fuser gears are
                      for me a result of bad lower pressure roller bearings..
                      you got ck them when hot as it doesnt always show
                      "cold"
                        • 37532
                        Re: MP5500 Fuser
                        Fusing pressure is done with the two springs. If you want to adjust, use the NIP band adjustment in the service manual. The springs themselves will over time weaken. You might get better results by replacing them.
