Charge Roller
  • staffie man
    • Aug 2011
    • 59
    [Misc] Charge Roller
    Hi all
    Just noticed a thread on the site stating that it was possible to buy MPC 3000 charge roller assy from a company in America, just wondered if there was a supplier here in the UK
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Charge Roller
    If they are the black Katun ones, it ain't worth it.
    • JustManuals
      • Jan 2006
      • 9838
      Re: Charge Roller
      Why don't you G-G-G- Google it?
      • Zaxxon
        • 608
        Re: Charge Roller
        Great help Paul, much appreciated...
        Please start you post with brand, model, problem.
        • staffie man
          • Aug 2011
          • 59
          Re: Charge Roller
          Thanks Ruben, T-T-T-T-Tried Paul.
          • qbert69
            • Mar 2013
            • 1152
            Re: Charge Roller
            E-B-B-B-Bay???
            REACH FOR THE STARS!!!
            Konica Minolta Planetariums!
            • logrady2331
              • Feb 2011
              • 301
              Re: Charge Roller
              You don't need to replace them at all. At set up we remove the charge rollers and apply Meguire's cleaner wax. Apply it just like you were waxing your car. (Aplly with a clean, soft cotton towel or wipe, buff the residual wax off and away you go). By doing this we routinely get 160 to 180k out of our PCU's. The charge roller will outlast the blade and drum by doing this little trick. N/A Trading mekas up a bottle chrage roller cleaner for IKON but you can get it by ordering 50.00 or more from them. You have to call and ask for it but they will sell it. It's pretty much just like Meguires cleaner wax in the red bottle. It works on all charge rollers.
              • tcs04
                FORMER Techie
                • 1183
                Re: Charge Roller
                You WAX THE CAR!?! ..-.... (Carwash, twice a year, Whether it needs it or not!)
                There MMMUST be a MMManual for this!
                • qbert69
                  • Mar 2013
                  • 1152
                  Re: Charge Roller
                  NuFinish works tttoo!
                  Our top-rated polishes, detailing products and protectants will help clean, repair and protect your car’s finish giving it that long-lasting showroom shine.
                  • staffie man
                    • Aug 2011
                    • 59
                    Re: Charge Roller
                    Hi all.
                    Thanks for the replies,part of the problem is the cleaning roller wears or falls apart when you try to clean it so the charge roller dirties quicker and with most customers every penny is a prisoner just now, one wont even replace their touch panel but prefers to prod & prod at it.
                    • Counsel
                      • Aug 2011
                      • 529
                      Re: Charge Roller
                      We also use the NuFinish wax we have used it for a while to wax drum and blades for black and white pms, I do use it from time to time on these color machine charge rollers, best to remove the springs on the cleaning roller so it drops out of the way or put paper between them so you dont rub felt stuff off the roller.
                      However from november to april i live in iowa and the weather is cold and very dry during winter and it wreaks havac on charge rollers the static in the air is aweful i spend a lot of time trying to keep charge rollers clean but after 1 attempt at cleaning if i have to come back i just replace the pcu otherwise it seems to be a reoccuring problem. would be nice if they sold just the charge roller but what do you do.
                      • qbert69
                        • Mar 2013
                        • 1152
                        Re: Charge Roller
                        A reply to "Counsel"--I can vouch for putting the paper between the charge roller and the sponge cleaning roller...an absolute must!
                        I use cotton cleaning pads for waxing and polishing too!
                        Regarding someone mentioning earlier of touch screens not working, sometimes the touch screen overlay if it is not physically damaged, will have crap and crud stuck underneath the bezel around the edge. You can try to take the panel apart and clean all the junk out that is stuck around the edge which gives false finger touch signals. If you clean it, it *may* work. Make sure you recalibrate it! YMMV!
                        • Lagonda
                          • Aug 2008
                          • 1649
                          Re: Charge Roller
                          You should be able to the the touchscreen from Ricoh for free. They know they had a major problem with them and for a while were giving labour rebates but now just hand out free screens here in OZ.
                            • 37553
                            Re: Charge Roller
                            Hi all.
                            Once the cleaning roller starts to deteriorate, it is time to replace the PCU. If it is maintenance customer, it will cost your boss less to replace it than to have a tech go out every week or o to clean the charge roller. If it a charge customer, give them an estimate to replace it and let them know that without replacement you cannot guarantee the cleaning of the charge roller and you will have to charge them every time that you come out to do so.
                            • staffie man
                              • Aug 2011
                              • 59
