1357ex Pro - Constant Functional Problems (SC495)
  • WoodyC
    • Sep 2010
    • 21
    [Error Code] 1357ex Pro - Constant Functional Problems (SC495)
    We have 2 1357ex Pro's here but one of them is giving me no end of grief. Count is about 3.5mill and for the last 4 or 5 months we have periods where it just keeps throwing up a functional problems screen (no error code). The engineer doesn't seem sure what the problem is and just and just plugs and unplugs connectors and cleans things out (his words). It then seems to be fine for a while. We've probably had 8 service calls for this problem over the time. I'd guess we get something like 70k between the issues.
    For example, I have a 12000 run to do. It did 8000 with no major problems but now will only print c150 copies before it errors. As far as I can tell the underlying error code is SC495 (from the data log).
    Does any one have any idea what the long term solution might be? I can't keep calling them out every month cause it's killing my production capacity.
    Michael
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: 1357ex Pro - Constant Functional Problems (SC495)
    Michael
    SC Tables: 4
    D059/D060/D061 4-36 SM
    Toner Bottle Unit Error
    During toner transport from the toner supply cylinder to the toner hopper,
    the toner hopper sensor cannot detect toner even after the toner supply
    pump switches on for 2 s and switches off 10 times during copying.
    SC495 B
    􀂃 Toner supply pump motor harness, connector loose, broken,
    defective
    􀂃 Toner supply pump motor defective
    􀂃 Blockage in the toner supply tube
    􀂃 Toner supply tube disconnected
    􀂃 Blockage in the toner supply cylinder
    􀂃 Toner-end sensor in the toner supply cylinder defective
    􀂃 Agitator in the toner supply cylinder defective
    􀂃 Toner supply cylinder agitator motor defective
    OPC.
    This is straight from the service manual ! Your tech should also look at TSB B234-12 for this issue. Most of the time when I get involved with this as ongoing, it's because the tech did not troubleshoot it correctly or they don't understand the toner system in these machines.
    Mystic Crystal Revelations
    • WoodyC
      • Sep 2010
      • 21
      Thanks for the reply Tonerbomb, I'll get him to check that if he hasn't. Would we have quality issues with those problems?
      • Tonerbomb
        • Feb 2005
        • 2589
        Yes!!!!!!!!!!!!
        • WoodyC
          • Sep 2010
          • 21
          Well that's strange then because the print quality is absolutely fine.
          • collme
            Ricoh tech
            • 221
            from goose guide
            D059/D060/D061 SC 495 Check toner supply motor voltage/trigger @ IOB CN 320 B2 and B5
            D059/D060/D061 SC 495 Toner bottle unit error - Agitator in the toner supply cylinder defective
            D059/D060/D061 SC 495 Toner bottle unit error - Blockage in the toner supply tube
            D059/D060/D061 SC 495 Toner bottle unit error - Check wiper blade on clear cyliner tube.
            D059/D060/D061 SC 495 Toner bottle unit error - Scraper in agitation cylinder not cleaning toner end sensor...
            D059/D060/D061 SC 495 Toner bottle unit error - Toner end sensor in the toner supply cylinder defective
            D059/D060/D061 SC 495 Toner bottle unit error - Toner supply cylinder agitator motor defective
            D059/D060/D061 SC 495 Toner bottle unit error - Toner supply pump motor defective
            D059/D060/D061 SC 495 Toner bottle unit error - update engine fw to 1.09.2.:04 or higher
            D059/D060/D061 SC 495 Toner bottle unit error. Suggest to check wiper blade on clear cyliner tube.
            • Counsel
              • Aug 2011
              • 529
              I would check firmware version make sure its up to date, then check the toner tubes and pump as well as the end sensor. If quality is fine and it throws the code i would guess firmware could be an easy culprit, you know how that goes a machine can run for years with its current version then out of the blue start doing something that was fixed later with firmware update.
                • 37489
                Intermittent problem could be a toner out sensor on the toner hopper starting to go bad. One way to test is to swap the toner hoppers only between the two machines and see if the problem moves.
                Change SP 5875-001 to 1 and reboot. Afterwards, the machine will display the SC every time instead of the reboot message.
                • ricoh
                  • Oct 2010
                  • 14
                  This issue is usually sorted by cleaning the toner lines and cylinder completely, being careful not to damage the toner detect sensors with static. Then replace the short section of tube from the toner cylinder to the toner pump unit. (B2343282).
                  Perform toner bank setup (SP2207-002).
                  Failing that, replace the toner pump unit (D0593260) and perform toner bank setup execution again.
                  • JustManuals
                    • Jan 2006
                    • 9838
                    http://www.justmanuals.com
                    Paul@justmanuals.com
                    • tinnyjay
                      • Oct 2009
                      • 663
                      We have 2 1357ex Pro's here but one of them is giving me no end of grief. Count is about 3.5mill and for the last 4 or 5 months we have periods where it just keeps throwing up a functional problems screen (no error code). The engineer doesn't seem sure what the problem is and just and just plugs and unplugs connectors and cleans things out (his words). It then seems to be fine for a while. We've probably had 8 service calls for this problem over the time. I'd guess we get something like 70k between the issues.For example, I have a 12000 run to do. It did 8000 with no major problems but now will only print c150 copies before it errors. As far as I can tell the underlying error code is SC495 (from the data log).Does any one have any idea what the long term solution might be? I can't keep calling them out every month cause it's killing my production capacity.ThanksMichael
                      To understand better your problem you must know that this code is generated when the toner does not go in toner hoper.So you must start from toner bank to the toner hoper to check everything about toner transport.See the coil if it is rotating first and see the tube if it is in its place,after that you must inspect tubes and pumps one by one.
                      "Who loves the roses,must also bear thumbs"
                      • WoodyC
                        • Sep 2010
                        • 21
                        Thanks everyone, sorry for the delay posting back. Aparently it's a clutch fault. A new one was fitted yesterday but unfortunately the engineer managed to snap a circuit board in the process of fitting it so now I have to wait for that part. I'll let you know if it fixes it.
                        • WoodyC
                          • Sep 2010
                          • 21
                          OK, changing the clutch seems to have done the job. But now there's another problem, which I will call about tomorrow but just in case anyone knows - is there a way to release the toner bottles when the push tabs aren't working? The machine is asking for toner but won't release the lower bottle to allow me to change it.
                          Michael
                          • Tonerbomb
                            • Feb 2005
                            • 2589
                            in sp mode 5804(output checks) there is an out put that will active the toner cap motor. sorrry I don't know the exact sp off the top.
                            • WoodyC
                              • Sep 2010
                              • 21
                              Thanks Tonerbomb. Have done that and the motors are activating, but I still can't get them to release. Will have to wait till they can come in.
