Ricoh Aficio 2027 Lines
  • Doug James
    • Jan 2012
    • 935
    It's hard to tell from the picture I attached but the lines look like it's originating from a bad drum. I did change the drum and blade and checked the fuser cleaned the laser lens etc... nothing phased it... Any Ideas would be a great help. Probably something simple I didn't catch... Attachment is printout of the copy counter
  • sandmanmac
    • 3983
    Re: Ricoh Aficio 2027 Lines
    If the fuser and drum are good, and this is actually a copy and print problem and not the old 'bent scanner' issue that causes lines on copies only, then I'm leaning toward a board problem. BICU maybe?
    • 'Tomas
      • Apr 2013
      • 12
      Did you stop the copy process? If so does the line originate from the process unit? If so, check and clean or replace the MC.
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        what direction is paper feed?? LEF or SEF??
        Mystic Crystal Revelations
        • Doug James
          • Jan 2012
          • 935
          LEF
          • Debs1964
            • Oct 2010
            • 1693
            Did you clean, or replace, the charge roller when you replaced the drum, the spacing of the marks looks like contaminated charge roller to me
            There are 10 types of people in this world, those who understand binary maths and those who don't
            • WWW
              • Nov 2013
              • 12
              Wait a sec... you say you changed the blade and drum. What about the charge roller?
              • Doug James
                • Jan 2012
                • 935
                Didn't change the charge roller, I just clean it real good and let it dry. This sure could be the problem... (I usually don't change charge rollers, up until maby now this hasn't been a problem)
                • sandmanmac
                  • 3983
                  That's definitely the cause. I misread the original post and assumed you'd replaced the entire PCU. I wouldn't consider rebuilding or using aftermarket PCU's- been there, done that, and it's not even close to being worth any of the presumed savings
                  • Doug James
                    • Jan 2012
                    • 935
                    Thanks so much !!! Really appreciate your help !!
                    • WWW
                      • Nov 2013
                      • 12
                      Great minds think alike! You must type faster than me though, because your post wasn't there when I started replying.
                      • Tonerbomb
                        • Feb 2005
                        • 2589
                        Debs is sneaky fast!!!!!!!!!!!!!!!!!!!!!!!!
                        • Debs1964
                          • Oct 2010
                          • 1693
                          I can't help being brilliant
