MPC 5503 Banding issue
  • speedyeubie
    • Mar 2014
    • 2
    [CQ] MPC 5503 Banding issue
    On and MPC 5503 I am getting a banding problem on halftones. When I run a full dot pattern on a 6 density CMYK all have varying forms of banding. The dev units have been replaced, the transfer unit, the transfer roller, and the k drum unit. The problem improved slightly after replacing all of that but it is still obvious on light prints, but not dark. Any ideas?
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MPC 5503 Banding issue
    Have you followed Technical Bulletin RD149064?
    RD149064.doc
    • speedyeubie
      • Mar 2014
      • 2
      I did not know about this bulletin, I had reviewed the bulletins on the tsrc site and didn't see this one. Thanks, I will try this today.
      • mikelc2
        • Feb 2015
        • 10
        Did you find this corrected the issue? It appears to be an ongoing concern for this 03 series.
        I applied the service bulletin and saw little to no results.
          • 37490
          Ruben is in Great Britain. Some of the things that they can get on MyRicoh in areas outside the US are not available here. Also, a lot of things that we can get on either TSRC or rfg-esource are not on MyRicoh there.
          It could also be that those bulletins that start with RD are for Ricoh Direct only and not directly available to dealer techs.
          • mikelc2
            • Feb 2015
            • 10
            If there's any other updates on this it would be appreciated. I'll post a print sample soon. The prints from these units are so terrible.
            • mikelc2
              • Feb 2015
              • 10
              Ok, ran some more test prints finally on this machine. After applying the service bulletin, there is a noticeable improvement, no further improvement with increased values.
              This machine certainly doesn't want to cooperate! For such a new machine, it shouldn't be having such issues.
              Sample Here
              • Zeldaman
                • Mar 2011
                • 946
                • justingm
                  Hi
                  We have exactly the same issue on a MPC5503 and the bulletin makes no difference to half-tones. Did yours end up being the laser at fault?
