MP 2000L2 SC 120
  • Lagonda
    • Aug 2008
    • 1649
    MP 2000L2 SC 120
    Its not often we have to ask for help but this one has us stumped, in fact its rather embarrassing having to ask for help with a half pint B&W!
    The problem
    SC 120 The scanner home position sensor does not detect the off condition during initialization or copying.
    However this only happens when you scan off the platen glass but doesn't do it when photocopying off the glass.
    The Attempted Fix
    So far we have adjusted the scanner position and the tension on the scanner drive belt several times. We have also replaced the following parts;
    Scanner motor, home position sensor, BICU, controller board and the SBU / lens block assembly and still no luck.
    The only thing we can think of is that it uses a different DPI scanning to photocpying.
    Any suggestions are more than welcome, just remember it only happens when scanning off the glass but not when photocopying or faxing.
    • 37560
    Re: MP 2000L2 SC 120
    You could try different scan resolution settings to verify your suspicions. I think that copy resolution is 600x600. Most scanning is 200 or 300. Also check your SMC non-default if available or SP mode data for any changed settings that have to do with stepper motor speeds.
    • Lagonda
      • Aug 2008
      • 1649
      Thanks Slimslob, I've sent a tech out to try that. I'll let you know the results.
      • Eric1968
        • 2458
        Could also be a bad harness of the scanner motor or home positioning sensor.
        • ruben
          The New Guy
          • Oct 2012
          • 1204
          From Goose's Guide (I assume you have already checked it, this is for anyone who hasn't):
          B276/B277 SC 120 adjust SP4015-2 to -0.3
          B276/B277 SC 120 Scanner home position error: Defective BICU
          B276/B277 SC 120 Scanner home position error: Defective scanner drive motor
          B276/B277 SC 120 Scanner home position error: Defective Scanner home position sensor
          B276/B277 SC 120 Scanner home position error: poor connection on BICU
          B276/B277 SC 120 Scanner home position error: scanner drive motor connector defective
          B276/B277 SC 120 Scanner home position error: scanner home position sensor out of position
