MPC5000 install black toner
  • Toner Boy
    • Aug 2007
    • 366
    pretty sure the black toner pump was bad swapped it with the yellow pump for temporary fix, cleaned out nozzle port but still have same issue any ideas? Gear that drives the pump clutch are spinning, near as I can tell. Loaded DV unit with enough toner to get it to work for about 30 pages.
  • sandmanmac
    • 3983
    Re: MPC5000 install black toner
    Bottle rotation clutch? Pinched /plugged hose?
