Ricoh mpc 2050 jamming before entering sorter
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Strange jamming issue. Paper fed from cassettes and from bypass copies fine but cannot exit into the sorter. All sensors have been cleaned and there is no obstruction in the paper path. Rollers in the exit assembly appear to be engaging and turning fine. Checked jam history and the regist reads 44 jams...tray 1 reads 36 jams..no fuser jams , no exit assy jams listed. Any advice appreciated. Problem occurred suddenly but nothing appears damaged or broken. Maybe a bad sensor.....but machine only has 20k copies.
  • elamurugu
    • Mar 2014
    • 27
    Re: Ricoh mpc 2050 jamming before entering sorter
    Take the copy with out sorter. The same problem continuve,clean the pickup clatch and registration clatch.
      • 37532
      Are the jams at registration late 017 or lag 057? My guess is that it is 057 since the lead edge of the paper is past the fusing unit. This means that the trail edge of the paper does not leave the registration sensor when the machine thinks it should. Check that the paper length is set correctly.
      • pattyboy7
        • Mar 2014
        • 21
        Is the copier detecting the right paper size?
        • rsyarcia
          Hair Straightener Tech
          • 711
          most of the issues that we encountered same problem that you have. replacing the exit sensor fixed it.
          Nobody is perfect..
          • blazebusiness
            • 1257
            Thanks for all the replies. Jam code in service mode was 24. Pointed to the paper never arriving at the exit sensor. Cleaned and replaced sensors and still not fixed. Upon closer inspection found that the flat extension of the white plastic solenoid lever that moves the black plastic guide (with the black teeth) was broken, which was sending the paper to the upper part of the paper exit assembly instead of exiting through the lower part as it was supposed to. Machine up and running again.
            • kannuki2
              • Feb 2012
              • 398
              look into the fuser's exit frame. the heat warped the metal frame .
              • stockman123
                • 128
                what kind of finisher the big stand alone does it have a puch unit in ti
                • Debs1964
                  • Oct 2010
                  • 1693
                  The MPC2050 only has one type of finisher available, the internal one
                  There are 10 types of people in this world, those who understand binary maths and those who don't
                  • ruben
                    The New Guy
                    • Oct 2012
                    • 1203
                    ... which is a POS, so don't buy it.
                    • Polarbear
                      • Feb 2012
                      • 1070
                      +1 on that stupid finisher!
                      Press the GREEN button!!
                      • CableGuy
                        Impulse Drive Engineer
                        • Oct 2008
                        • 417
                        Think there is a bulletin out on this model were the exit sensor or the one before it goes faulty, can only be cured by replacing said sensor. Had a couple go in the field.
                        This is it...
                        Cheers
