When I first looked at this machine it was 30k past a PM. So I did the PM. I replaced the drum & blade, charge roller
and blade, transfer belt and blade and developer mix. Vacuum out loose toner and clean.
I carefully followed the directions in the book and covered the dev openning
when I ran the dev initialization, and other programs. Also the seals around the developer ports and on the toner
bottle holder have been replaced. There was a lot of toner dusting from this that was getting on the laser glass.
I thought that would have taken care of the problem but nope. It did stop the dusting though.
With the amount of dusting I am wondering if the last mirror in the laser assembly could be dirty?
Has anyone had a similar experience?
DR
DR
