Aficio 3045 low density area trail edge of everything printed or copied
  • Desert Rat
    • May 2008
    • 1089
    When I first looked at this machine it was 30k past a PM. So I did the PM. I replaced the drum & blade, charge roller
    and blade, transfer belt and blade and developer mix. Vacuum out loose toner and clean.
    I carefully followed the directions in the book and covered the dev openning
    when I ran the dev initialization, and other programs. Also the seals around the developer ports and on the toner
    bottle holder have been replaced. There was a lot of toner dusting from this that was getting on the laser glass.
    I thought that would have taken care of the problem but nope. It did stop the dusting though.
    With the amount of dusting I am wondering if the last mirror in the laser assembly could be dirty?
    Has anyone had a similar experience?
    DR
  • rthonpm
    • Aug 2007
    • 2859
    Re: Aficio 3045 low density area trail edge of everything printed or copied
    Check the top cover of the developer unit and make sure the mylars haven't been deformed. If I recall, there was an issue where the top cover for this model was modded to prevent the mylars from giving partially light output.
    • sandmanmac
      • 3983
      Removing the laser and cleaning all mirrors/reflectors would definitely be the next step for me.
      • vargue
        • Oct 2011
        • 404
        this nightmare threat encountered me .i replaced laser and full cleaning to all parts of machine and replace Mylars.customer every day call me out light density in trial edge and clean shield glass and more more ..... it's tank problem. swap with another tank
          • 37553
          If it was toner in the laser housing, the light area would be along the direction of paper travel, not the trail edge. Avoid opening the laser housing as you can let in more dust than you are removing. Clean any spewed toner before removing the laser shield glass for cleaning. I agree that it has something to do with the development unit. Check the gears on the development roller assembly. If they are worn, toner in the developer on the development roller could be getting depleted and then getting enough revolutions to be replenished between copies.
          • sandmanmac
            • 3983
            Oops. Yes. I agree. My bad. I misread title of this post
            • Herostrat
              • Oct 2012
              • 220
              Swaping toner hooper may or may not solve your problem,in more than one ocasion it was the sponge on PCU entrance for toner on it's way to developing assy.
              When I saw PCU without that sponge I vacumed ewerything and let them test it on about 100 prints...what ewer they needed at that point...one can't imagine how much toner goes out of there.
              Then I improvised some sort of sponge filling on it and we ran another 100 prints and it was clean,hope this helps.
              • Desert Rat
                • May 2008
                • 1089
                Thank you all for your help,
                As I think about it the low density does follow the paper feed. I will check the
                developer unit mylars and gears as well. I've had to many calls on this unit already.
                The tank, I assume, is the developer unit?
                Since replacing the seals on the dv and replen units the dusting has stopped.
                I'm leaning toward the laser unit, but will double check the items mentioned.
                Thanks again for the good advice
                DR
                • Desert Rat
                  • May 2008
                  • 1089
                  Herostrat, every bit of info helps. I did the same thing to stop the dusting mess. Replaced the seals.
                  DR
