Ricoh aficio 3025
  • khaled_abosere3@yahoo.com
    Head technical support
    • Mar 2012
    • 171
    [CQ] Ricoh aficio 3025
    First I have used merging application to install (printer / scanner option ) I do as sequence maintained in manual (Printer/Scanner Unit Type 3030, Printer Unit Type). 3030.
    then machine worked well printer and scanner but there is message displayed on LCD tell us:
    *cannot install this software
    *this software has already been installed on another machine
    all I want is to disable this message just.
    with my greetings.
    • 37560
    Re: Ricoh aficio 3025
    You mentioned that you used merging. Merging usually means that the option(s) on one SD card have been moved to another SD card using SP 5873-001. The original SD card is then removed. If it is not removed you will get this message when the 3030 detects a SD card that does not have an option on it nor does it have a firmware update on it. The same message will come up if you try to used a SD card that has already been merged on another machine.
      • Mar 2012
      • 171
      The original SD card has removed and the message still displayed.
      with my greetings.
