Nashuatec 4545
  • JACK MUNDA
    • 9
    [Error Code] Nashuatec 4545
    This machine generates 990 after a no. of copies ,the drum and developer all new.Serviced the unites and adjusted image pixel SP 2208-001 n what i get is frequent over toning any ideas to stop the over toning.
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: Nashuatec 4545
    clean the all contacts on the bias.
    Nobody is perfect..
    • CrapAimer
      • 296
      Re: Nashuatec 4545
      Check the Developer, and the drum when worn they can throw up this code.
        • 37502
        Re: Nashuatec 4545
        When you replaced the drum and developer. did you also replace the charge roller? Clean the image density sensor with a damp cloth and execute SP 3001-002. Check SP2103-001 thru 004 to see if they are at or near +64. Return SP 2001-001 and SP 2103-001 thru 004 to their default values. If the problem returns, you might have to replace the laser diode unit.
