Ricoh 8001sp
  • kannuki2
    • Feb 2012
    • 398
    Re: Ricoh 8001sp
    Originally posted by Old Crow
    just a follow up to this problem. I replaced all of the guide plates with mylars and this did the trick. I guess the paper fed ok from drawers two and three because the paper is coming straight when the lead edge hits the reg rollers as opposed to coming from an angle from the top feed unit. thanks for all the ideas and suggestions with this problem.
    Crow, which guide plates with mylars? is it on the paper feed unit? or on the registration unit?
    • Old Crow
      • Aug 2011
      • 201
      Re: Ricoh 8001sp
      I replaced all plates in the reg./bypass section that have mylars on them. Some that you can't see until you actually remove the plate itself were quite worn.
      • TonerMunkeh
        Professional Moron
        • 3865
        Re: Ricoh 8001sp
        Part numbers are B140 2665 and 2675. I replace them between 600k and 1m depending on how shit the customer's paper is.
        Hit it.
