RICOH MPC 2500 SC 565
  • reunited
    • Apr 2014
    • 5
    Hello,
    Two units of my MPC 2500( 110v) encountered this SC 565 error. I believe it should be Fusing unit issue but can someone help with more details?
    TQ
  • skynetto
    • Sep 2012
    • 257
    Re: RICOH MPC 2500 SC 565
    Hot roller lamp stay on for more than 120 seconds.
    1. Check/replace Thermostat - 146c/147c (AW11 0055) and hot roller lamp.
    2. Replace PSU
    That's what Ricoh tells about.
    Goose tells this
    Code:
    [TABLE="width: 502"]
    [TR]
    [TD]PR lamp consecutive on error - A level error, reset with SP5-810[/TD]
    [/TR]
    [TR]
    [TD]PR lamp consecutive on error -  Check harness wire ties at machine side of harness. Reports of wire ties crimping harness.[/TD]
    [/TR]
    [TR]
    [TD]PR lamp consecutive on error -  check/replace thermistors, verify  with SP1-106 001[/TD]
    [/TR]
    [TR]
    [TD]PR lamp consecutive on error - replace thermostats AW11 0055 Thermostat - 146c/147cm - AW11 0058 Thermostat:177c - AW11 0059 Thermostat:190c[/TD]
    [/TR]
    [TR]
    [TD]PR lamp consecutive on error - replace PSU[/TD]
    [/TR]
    [/TABLE]
    • reunited
      • Apr 2014
      • 5
      Dear Skynetto,
      Thanxs for the infor...actually i tried but I m run out of 110v thermostat....do u think 240v thermostat(for mp c2500 as well) will fit in?
      2. Replace PSU
      Goose tells this
      Code:
      [TR]
      [/TR]
      [TR]
      [/TR]
      [TR]
      [/TR]
      [TR]
      [/TR]
      [TR]
      [/TR]
      [/TABLE]
        • 37419
        Originally posted by reunited
        Dear Skynetto,
        The critical thing on thermistors is the temperature at which they open, the physical size and the way they connect.
        • reunited
          • Apr 2014
          • 5
          All right...so u mean if i replace a 240V thermostats & thermistors into my 110V fusing unit should be fine, right.
          • Iowatech
            Not a service manager
            • 3930
            Thermostats?
            On the other hand, I'd be inclined to check the thermistors first, too. A thermostat is unlikely to have much to do with the lamp staying on too long unless it was rated for a much higher temperature than what the original ones in the machine were, or it was shorted out. And even if that was the case, there would have to be something else involved too. Like an incorrectly installed hot roller thermistor (too far away from the hot roller), or the pressure roller thermistor had a blob of toner stuck to it or wasn't in contact with the roller. Or the fusing belt or pressure roller was worn out or the bearings were out of position.
            • reunited
              • Apr 2014
              • 5
              So...should i change a 240V thermister into a 110V fusing unit? no voltage issue?
              Originally posted by Iowatech
              Thermostats?
              • Gift
                • Mar 2011
                • 2459
                I'd bet the tiny thermistor element on the press roller thermistor is loosen from it's metal/teflon plate
                • mikadonovan
                  • May 2008
                  • 2931
                  Every time I have this code on this model the pressure roller thermostat is blown and the pressure roller thermistor is dirty. It is possible to replace the thermostat without pulling the pressure roller, but you have to hold your mouth just right. I just did one of these yesterday.
                  NEVER ASSUME ANYTHING
                  • ruben
                    The New Guy
                    • Oct 2012
                    • 1203
                    You can easily remove the pressure roller thermostat by engaging the pressure levers, which just gives you enough room to remove the thermostat and its holder.
                    • Iowatech
                      • 3930
                      As the thermistor is supplied with a DC voltage from the power supply, I'd guess you would be OK as long as they are for the MP C2500 (they should even have the same part number). To the best of my knowledge, the DC voltage outputs from the power supply are the same no matter what the input AC voltage is.
                      As far as the thermostats go, be careful there. Theoretically, the thermostats from the 110 VAC machines and the 240VAC machines should have similar maximum temperatures, so there is a chance the ones you have could work. But if the ones for the 240VAC machine aren't the same size or shape as the ones in the 110VAC machine and don't fit properly, they won't work. The amount of space between the thermostat and the heat source is critical for protection from overheat errors.
                      • he7060
                        • Jul 2015
                        • 14
                        2. Replace PSU
                        Goose tells this
                        Code:
                        [TR]
                        [/TR]
                        [TR]
                        [/TR]
                        [TR]
                        [/TR]
                        [TR]
                        [/TD]
                        [/TR]
                        [TR]
                        [/TR]
                        [/TABLE]
                        you have to replace the fusing unit ... you can reset the error code, next morning you will have it again ... sc565
                        CopierMaps Team
                        CopierMaps: Copier Dealer Locator | Copier Lease Guide | CopierMaps.com
                          • 37419
                          CopierMaps Team
                          Did you look at the original start date of the thread?
                          • he7060
                            • Jul 2015
                            • 14
                            yes... but a lot of other people might find it as very useful information ...they try to replace the thermistors or PCU (Ricoh Service Manual) on this Ricoh MPC2500, MPC3000 with error code sc565 which is a waist of time and money.
                            Fusing unit should be replaced at this point.
                              • 37419
                              Why waste money on a complete fusing unit when the actual problem is an open thermostat caused by a bad thermistor. Use your meter and check the thermostat. If it is open order a new one along with the thermistor.
