ricoh mpc6000 add toner disable code
  • BATA
    • Mar 2012
    • 27
    hello dear friends , for ricoh mpc6000 /7500 I need to disable the add toner signal so that I can refill it
    with compatible toner , so please till me the sp code for disable toner signal without replacing the toner chip
    also can i use toner of mpc3500 to refill mpc6000 , thanks
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: ricoh mpc6000 add toner disable code
    Your just asking for a bad day!!!!!! very very Bad idea!!!!!!! The c6000 runs dirty enough as it is..................................
    Mystic Crystal Revelations
    • sandmanmac
      • 3981
      Then he'll be back here in a week asking how to resolve an SC or a copy quality issue, completely neglecting to include the fact that he's refilled the toner bottle with a compatible brand for different machine! And wondering what could possibly be wrong???
      Unbelievable!
        • 37533
        Originally posted by JustManuals.com
        This Parts & Service Manual can now be purchased for $14.77 and downloaded immediately from:
        Paul@justmanuals.com
        Obviously he needs one. If he had one he could just look up the code.
        Unbelievable!
        The only time I have ever disabled the toner % detection is when either the RFID board is bad while I order in new one or on a Ricoh national account with a bad RFID chip while they get a new toner cartridge from Ricoh. Refilling toner cartridges on any equipment ultimately costs more than it save.
        • turbojetboy
          • Aug 2009
          • 279
          Not possible, MPC 6000, 7500 6501, 7501 use a trickle feed development system and a percentage of developer is contained in each bag of toner - so no other ricohs have compatible toner. You should leave this machine alone as you obviously have no idea what your doing.
            • 37533
            If I remember from the class, the toner contains 1% developer. That is why you cannot use the yellow toner to powder the drums or ITB.
