mpc2030 SC220
  • mr.daus
    • Apr 2011
    • 98
    mpc2030 SC220
    any one can help me for solving my problem with code SC220 on mpc2030
    firdaus +(62)8195002007 firdaustrish@ymail.com
  • kwame
    • May 2014
    • 11
    Re: mpc2030 SC220
    SC220 is a Laser Synchronization Detection Error either a polygon motor fault or a board control it try to reset before that
    • kwame
      • May 2014
      • 11
      Re: mpc2030 SC220
      In Copier service mode, press the yellow button, then 107 then the red Clear button and keep pressed until the screen changes, please take note that you need to do this quickly or else otherwise it wont work , hope you will successfully go in SP MODE but be careful what you change because you will mess up the
      • mr.daus
        • Apr 2011
        • 98
        Re: mpc2030 SC220
        what can i do on SP mode with sc220?
        PCDU was cleaned and laser unit too
        should me replace a electronic board?
        • kwame
          • May 2014
          • 11
          Re: mpc2030 SC220
          Try to reset an error boss before doing that sometimes it helps
            • 37560
            Re: mpc2030 SC220
            Per Goose's Guide, check laser connection, replace Laser unit, Replace BCU board.
            • mr.daus
              • Apr 2011
              • 98
              How to reset him?
