sp420dn
  • vargue
    • Oct 2011
    • 404
    [Misc] sp420dn
    hi fellas i have some headache in this printer.it's in guarantee .cyan unit was bad i change it.but when i look at picture cyan color very strong. make changes in picture color. there is some clue
  • sandmanmac
    • 3983
    Re: sp420dn
    Originally posted by vargue
    there is some clue
    I certainly have no clue.
    'A picture is worth a thousand words'.
    Please post some samples of the problem Vargue
    • CRISTIAN MULLER
      • Feb 2013
      • 145
      Re: sp420dn
      Did u Check TD and ID sensor?try to print like 20 or 30 pages full cyan and initialize developer, see if will hold this new amount of toner, if back overtoning change PCU and reinitialize developer.
      • duane@pbbsinc.com
        • Mar 2011
        • 77
        Re: sp420dn
        I do believe you can change the manual gamma settings for just the cyan to tone it down cause it is stronger than yellow and magenta since you just changed it.
        Or access service mode and tone up magenta and yellow and then perform engine color calibration.
        • CableGuy
          Impulse Drive Engineer
          • Oct 2008
          • 417
          Re: sp420dn
          Not uncommon for toner hoppers augers(doesn't really have a pump as such) to foul up and not drive toner to the pcu.
          good luck changing one of those... lots of fun
