Ricoh MPC4500 address book problelm!
  • Hadster
    • Aug 2011
    • 264
    [Misc] Ricoh MPC4500 address book problelm!
    When I go to Authentication info page in the address book it is blank!! System settings - admin tools - address book management - user - Auth. Info - and no user code to put in and no SMTP authentication to be found. Things I have done so far!
    1- upgraded firmware
    2- HDD formatted
    3- reset to factory default copy and system
    • 37553
    Re: Ricoh MPC4500 address book problelm!
    You need to turn User Authentication on in System Settings - Administration Tools - User Authentication. Indicate which functions will require user login. Individuals do not authenticate to the SMTP server.
    • Hadster
      • Aug 2011
      • 264
      Thanks! Already did that!
      • sharpmind
        • Sep 2009
        • 478
        What is the latest code in SC history?Why not try to replace the HDD. Sometimes it happens that even you reformatted the HDD, you cannot add names to address book. Simply because the HDD has many bad sectors.
        • Athlontini
          • Jun 2012
          • 269
          Don't you have to be logged in as Admin?
          • Debs1964
            • Oct 2010
            • 1693
            Yes, if admin authentication is turned on, then you have to be logged in as admin to see, or change, these settings
            There are 10 types of people in this world, those who understand binary maths and those who don't
