Ricoh 2550 dirty copies and switching to 1027 PCU
  • aikens
    • Oct 2011
    • 16
    [Misc] Ricoh 2550 dirty copies and switching to 1027 PCU
    Hello All;
    Have a Ricoh 2550B with dirty copies. Optics are all clean so I assume it needs new drum and developer. Here's the question. Can I switch to the 1027 pcu without changing the transfer roller assembly?
    Thoughts?
  • Athlontini
    • Jun 2012
    • 269
    Re: Ricoh 2550 dirty copies and switching to 1027 PCU
    Yyyyyyes...?
    The transfer roller has a yield of 120k; it's meant to be changed along with the fuser rebuild.
    • rthonpm
      • Aug 2007
      • 2859
      Just remember that you'll need to manually do the developer initialisation even with the PCU.
      -- sent from my BlackBerry using the Android app
      • Zeldaman
        • Mar 2011
        • 946
        Hi there!
        RICOH (Germany) sais NO! But there is really no problem, you can use the #1027 PCU as it is, only doing the sp 2-801. We make this with all our late "RUSSIAN", and had no trouble.
        Greetings...
        • Wind Cool
          • May 2014
          • 82
          Originally posted by aikens
          Hello All;
          Thoughts?
          Hi !
          You can use Ricoh 1027 PCU for Ricoh 2550B without any problem, just need to do the Developer Initialize.
          Oh.... one more thing, the PCU 1027 life spend is 60K... but you can try to use up to 120k ~ 140k by changing the Drum & C/Blade Only. (The Developer can use more then 120k)
