Ricoh
  • laser801
    • May 2014
    • 151
    Ricoh
    I have a ricoh with fax option that is sending faxes to different # than dialed.... comes up on display when communicating as wrong # as well...maybe a setting...
  • Eric1968
    • 2458
    Re: Ricoh
    Model???
    The number you see in the display may not match the number you've dialed. The number you see is the number that has been programmed in the other machine.
    • sandmanmac
      • 3981
      Re: Ricoh
      Exactly. Or maybe it's been forwarded to a different location or web hosted fax server.
      This is not 'new'.
      • Eric1968
        • 2458
        Re: Ricoh
        This is not 'new'.
        It's called Basic Knowledge...
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          Re: Ricoh
          When you really want to know what a device is dialing you need a tool like the Faxmate test tool. It has a digit grabber function that will display the digits that are dialed on the pstn or pbx...............................
          Mystic Crystal Revelations
          • laser801
            • May 2014
            • 151
            Re: Ricoh
            Model???
            Thanks Eric... the fax does not go to the right number...also when I put the other Brother 4100 back in place, everything is fine ...goes to correct number...
            • ruben
              The New Guy
              • Oct 2012
              • 1203
              Re: Ricoh
              Do a memory clear on the Fascimile Application (SP5-801-007), if that fails you may have a faulty fax board.
              • teebee1234
                • 1670
                To be clear, is the correct number displaying as you type it in and then changes once you select start?
                Have you tried calling your cell with it?
                • Iowatech
                  Not a service manager
                  • 3930
                  Re: Ricoh
                  No Ricoh model number yet?
                  That's odd.
