Ricoh C7105
    • 23008
    Ricoh C7105
    It's a new model for me. I've got cyan toner puking out of it, clearly overtoning developer problem. I've already vacuumed up 1/2 cup of cyan toner from the lip below the developing cylinder, and it immediately filled up again.
    As the guy who makes a big deal about reading the manual, I must say that I don't have the manual, but I'm working on getting it.
    In the meantime, what's involved in doing the cyan developer stir, and a basic color calibration? Anything else I missed?
    I noticed that it's got some sort of a drum ground modification to the image section cover. What's this intended to fix?
  • Meach
    • Nov 2008
    • 128
    Re: Ricoh C7105
    Could the model be a C7501 ?
      • 23008
      Re: Ricoh C7105
      Oops! Yes it's a C7501, and it's got 234K black and 198K color on the counter. =^..^=
        • 37494
        Re: Ricoh C7105
        Ricoh has put out a number of bulletins on this beast puking toner. PM me if you need any Ricoh docs while Paul is in the hospital. See my attachment in the following thread: charis pro c5100 proc 5110 toner use and waste toner yield. It gives some settings that can help with some of the Ricoh color units.
          • 23008
          Re: Ricoh C7105
          Thanks slimslob, emo. This is a good start.
          Every Ricoh I've ever worked on has overtoned. Long time Ricoh users get kinda used to the piles of toner on the paper, and cannot understand the concept of half-tones or white background. "You mean it's not supposed to be like braille?"
          Any comments on the home-made drum shaft grounds? =^..^=
          • Lagonda
            • Aug 2008
            • 1649
            Re: Ricoh C7105
            Hi Black Cat,
            and you thought busted ankles were painful, welcome to the terrifying world of the Ricoh Venus range!
            These boxes are ho hum until you try to push them beyond their design limits, the moment they go past 40% colour ratio they turn in to toner spewing pigs.
            No real answer to this ( well we haven't found one) apart from increase the PM cycle. We have a complete set of PCU's on the shelf ready to hot-swap so you don't spend hours in the customers office deafening them with the vacuum cleaner.
            So chin up and soldier on and keep a spare filter cartridge for you vacuum on hand.
            If you get really depressed about it you can hunt down the salesman that told them they could use it as a production machine and set light to his pubic hair.
            Doesn't fix the copier but you will feel better.
            • Tonerbomb
              AutoMajical Resolutionist
              • Feb 2005
              • 2589
              Re: Ricoh C7105
              bc you can also PM me as I deal with these animals too!!
              The homemade drum shaft grounds do help if made correctly, or option B is to buy the manufactured ones from NA Trading. The one's from NA work well, but are about $40. Pretty pricy, but they are copper................
              Mystic Crystal Revelations
                • 23008
                Re: Ricoh C7105
                So far, slimslob has pointed me in the direction of Bulletin D081/D082-035. To my surprise it worked like a charm, at least the first 4 or 5 steps. When I got to the part about engine firmware 1.06:06 I stopped, for fear of reversing the improvements I've seen so far.
                It's currently at firmware 1.04
                I was delighted to leave it better than it started (I know it's temporary, but I'll take it). =^..^=
                • Iowatech
                  Not a service manager
                  • 3930
                  Re: Ricoh C7105
                  Um, I'm not familiar with that model, so maybe take this more as entertainment than service advice?
                  Back in the day, we found that on the 35/45 CPM machines sometimes the drum ground was lacking, and modified a common copper conduit mounting bracket to compensate for that. It would mount on one of the screws on the high voltage board, and needed to be taped up really well to avoid shorting things out. But when "reformed" correctly it would always contact the center of the drum drive shaft, and it did more good than harm.
                    • 37494
                    Re: Ricoh C7105
                    Glad I could be of some help.
