I am trying to log in as the supervisor in order to change the user name and password . When I log in as Supervisor it prompts me for another password and fails authentication . Is there something I need to enter in the supervisors password or is there a problem with the eprom ?
Ricoh 3351 supervisor log in
Re: Ricoh 3351 supervisor log in
The default password for the supervisor is blank ( no password) if it requires one then someone changed it. There fore you need to either get it from the admin that changed it or there are many posts that detail some of the things you can try to reset it.Mystic Crystal Revelations -
factory sp modes ?Comment
Hello, just re awakening this thread to find out if anyone has actually executed SP 5846-46
if so, how did it turn out? I intend to log this onto my cheat sheet but want to make sure that it is tried and tested, before my boss has my nuts.
thanksComment
Yes it worked thans again.Comment
