Ricoh Aficio CL7200 - Remaining Alert Msg
  • repairgirl
    I recently replaced the Fusing Unit (Type C) but the alert light continues to stay on along with the message to replace the fusing unit. What do I need to do next? Thank you.
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    1. Go into service mode and reset the PM counter for the fuser manually.
    or
    2. Take the top cover off the fuser and re-connect the small spring next to the gears.
    • repairgirl
      I prefer to try the first option. Fusing Unit are expensive. Could you give me more instructions to resetting the PM counter please...Thank you kindly!
      • Cipher
        • May 2006
        • 1309
        PM'ed.
        • hcklbry
          how do you enter service mode
          Could you please send me the instructions to enter service mode? I have the same problem. I correctly installed a new fuser unit today and the alert still remains. Thanks.
          • repairgirl
            Forgive the delay to my reply. Here are the instructions I kindly received from "Cipher". It worked for me! Truly, Repairgirl (^_^)/
            Fuser PM reset
            1. Hold the 'up' and 'down' arrows together for 5 seconds or longer.
            2. Release the arrow keys and press the 'enter' key.
            3. Select '2. Engine'
            4. Go to SP7804-016 (PM Counter Reset>Fuser) and execute.
            5. Turn the machine off and on.
            All done.
            • rthonpm
              • Aug 2007
              • 2849
              I have a CL7300 (LP 335c) in my territory. Since I just have the one I've been using the standard B1809511 drums in it, but with the faceplate of the old drums on it. Is there a way to re-set the PM counter for specific units (PCU, dev, fuser) for this model as well? The little white encoder for the drum unit doesn't always re-set so the PM counters look unusually high.
              Thanks in advance
              • Cipher
                • May 2006
                • 1309
                It's the same on the CL7300 just scroll through SP7804-XXX and clear the PM counter manually for each part (everything is clearly named).
                Do not manually clear the PM count on used dev units though.
