c2800 sc547
  • tinfox
    • 317
    c2800 sc547
    This machine was working perfectly until it was hooked up to a diesel(?) power generator at a construction trailer. I've tried clearing the code (off-on 5810, execute, off-on). There do not appear to be any obvious blown fuses on the PSU.
    Before I order a PSU, is there not a circuit breaker on this machine? I searched both the parts and service manuals and there was no mention of a breaker of any kind.
    TIA
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: c2800 sc547
    Copiers don't do too well with generators. There are several soldered fuses on the PSU, might be worth while checking them, or just swap the whole PSU.
    • tinfox
      • 317
      Re: c2800 sc547
      Are those the flashlight bulb looking things?
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        Re: c2800 sc547
        According to the manual the PSU has 14 fuses (FU1 to FU14). You can find them on the board marked with these characters. I doubt it is this, it is most likely that the generator isn't providing a constant power supply.
        • tinfox
          • 317
          Re: c2800 sc547
          I see in the manual all the fuses but there are only six on this psu. 4 on the left and 2 on the right. See Pic. Are there more on the back of the psu?
            • 37491
            Re: c2800 sc547
            [ATTACH=CONFIG]25028[/ATTACH]
            Those are the ones mounted in fuse holders. The others are probably solder mounted fuses or fusible links. As ruben said, look at the lettering printed next to each component on the board.
            • tinfox
              • 317
              Re: c2800 sc547
              I see. I never knew about those. Today is a good day. I learned something! Thanks fellas :-)
              Look what I found!
              The fuse there checked out okay, unless the current went the other way around, idk. So I may try replacing that jumper.
              I haven't held a PSU board in my hands for quite sometime. Wow, are they printed on paper or what? I've gotten birthday cards that were more sturdy.
              Thanks again for your help.
                • 37491
                Re: c2800 sc547
                From the discoloration in that area, I would say that something there blew.
                • hotsun
                  • Dec 2013
                  • 12
                  Re: c2800 sc547
                  Advantages of high quality compatible copier drum unit,RICOH 1013.1015.1515.1027.3500.5000b.MPC2050/2550.MPC2500/3500.MPC2800/4000.
                  • Herostrat
                    • Oct 2012
                    • 220
                    Re: c2800 sc547
                    I wuldn't unsolder those on my own,fuses aren't the only ones to blow up in such cases from my experience.
                    Those big round coils are the ones to blame sometimes...I'm not shure how is it called in English but literal translation wuld be "silencer".
                    Electronic workshops handle those wery well for us,and ye it's like it was made on paper so take care,I'we seen one broken in half.
                    If you do try to fix it on your own be shure to have working PSU board close for comparing...once you are done with it compare Ohm resistance on pluged power cable,I can't recall exactly but I think that it shuld show around 40kOhms,anything below that will make fuses blow,bes hure to check it and correct me if I'm wrong pls,Good luck.
                    Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
