Infotec Pro 907 ex
  • ChrissyG
    • Jan 2013
    • 30
    Infotec Pro 907 ex
    907 smudge.pdf
    Had new transfer unit and drum
    • 37377
    Re: Infotec Pro 907 ex
    My guess would be either a dirty laser shield glass or a dirty doctor blade.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      well when I thought about it, I disagree slimslob. The counter page by default prints from tray 1 long edge feed. So since the drum and transfer were replaced, I would consider some issue with drum drive or transfer drive. Either way I would inspect what has been replaced, since there is no comment stating this happened after service or was going on before service. And is the blur on lead edge or trail edge?????? My $0.02 worth.....
      Mystic Crystal Revelations
      • 1nevster
        • Dec 2010
        • 49
        There is a clip on entrance guide on the transfer belt assembly, these often get worn and can get a sharp edge on that the lead edge of the paper hits causing the paper to stall. Check this. worth a shot.
        • chivozx
          • May 2014
          • 34
          • Ivan FSA
            • Apr 2014
            • 6
              • 37377
              Using Google translator:
              Before replacing any parts, I esperimentaria polish the cylinder with Zinc Stearate ..
              Get some machines that copy comes out with this default, is usually moisture.
              Can someone translate!
              • imaginemoko
                unTrusted Tech
                • Jan 2008
                • 289
                i would also guess on the drum drive its either the belt drive is worn out or a toner cake on the drive gear or the drive of transfer gear a teeth possibly broken. best of Luck Sir.
                fix the customer first then fix the machine... its simple and makes life more easy.
                • freginold
                  • Sep 2010
                  • 102
                  seen something very similar to that a couple times, where toner on the drum drive gears caused it to mess up the image like that. we cleaned up the gears and the problem went away.
                  Config page instructions for copiers, printers, & fax machines
