Ricoh 470w
  • bat
    • Sep 2008
    • 140
    Ricoh 470w
    Hi all...
    M having a problem with 470w when printing or copying im getting a smear on document. The machine is regularly serviced and all PM parts are in yield. It happens on all media and paper formats.
  • jdzr
    • 125
    Re: Ricoh 470w
    On your sample it is really hard to see a "smear" but I do see a lot of uneven copy density. I f this is the case try cleaning the underside of the lens. Even though it is serviced regularly this seems to be one thing most guys miss.
    • copiman
      • Sep 2011
      • 861
      Re: Ricoh 470w
      If it does in when printing and copying, I would look at a hesitation in the transport of the paper. Try different trays and the bypass to see if its related to ant particular paper source. Been a long time since I worked on wide body machines. Hope this helps.
        • 37532
        Re: Ricoh 470w
        Since it does it both when printing and copying, I would look for a dirty laser shield glass, dust or toner on the mirror and lenses in the laser or uneven distribution of the developer, possibly due to a dirty doctor blade.
        • rsyarcia
          Hair Straightener Tech
          • 711
          Re: Ricoh 470w
          the machine doesn't have a laser unit - it using LPD - Led Print Head. - clean or replace the corona wire and the grid wire.
          Nobody is perfect..
          • duct tape
            • Jun 2009
            • 87
            Re: Ricoh 470w
            Check the separation transfer unit to see if the guides over the corona wires are in the correct position , they can be placed in the wrong spots causing that and sometimes void areas. They are different sizes ,and can be mounted wrong
