Good day, everyone.
I have been working on a customer's machine for a gray background and overall dismal copy quality, including random streaking, blotches of toner and dirty backside. The copy count is 880k and the customer is holding out for another 6 months until they settle a case and can buy another one. So, repairing this one is what they want to do.
I know it is a toner-belching, much maligned, dirty, foul piece of machinery, but the customer likes not making monthly payments.
Here is what I have done.
1. Changed the Developer unit out with another one - same result
2. Changed Drum unit with another one - same result
3. Changed power supply board - same result
4. Changed transfer section out - one side of theirs was broken and the original reason for the call
5. Cleaned the inside of the machine thoroughly, including the glass under the toner supply - no change
6. Put new seals on the drum unit and developer unit to keep the inside of the machine cleaner.
7. Cleaned registration roller thoroughly.
8. Pulled the Developer unit, replaced all the gaskets and seals, cleaned the filter, cleaned the mag roller and changed developer today - no change. Ran the developer initialization, TD initialization and the ID sensor properly per the manual.
I have changed some of the settings in the service mode, but nothing has really gotten me to an acceptable copy quality. Based on an evening of looking through the forums, I have come across three possibilities.
1. Doctor blade out of adjustment. I don't know how it cold be, there was no adjustability that I could see.
2. Both drum units I tried were bad and I need a new drum unit
3. Bad TD sensor (how can I test this?)
Tonight I was looking at the old, broken transfer section and noticed it was PACKED full of toner. I will check the one I swapped it with and see if that one is packed, too.
I have read a gap of .35 MM between the Doctor blade and the mag roller. Is that right? What can I use a gauge for that - a sheet of copy paper?
Here is a piece of important information: I am getting clumps of toner on the drum and the transfer section. I will take a picture and post it tomorrow.
Long posting, but I wanted you to know I am doing this only after having tried the above items.
Thanks!
Thanks!
