ricoh mpc4500 - White copying
  • rich1106
    • Feb 2014
    • 21
    Hi!
    I have a ricoh MPC4500. When I want to copy or print a counter. not show the image on the sheet goes completely white. Transfer has been checked, the OPC modules, engines.
    Everything works perfect. Any suggestions about this problem?
    Thanks for your help!
  • Max
    • Oct 2011
    • 561
    Re: ricoh mpc4500 - White copying
    blank copy?
      • 37560
      Have you checked the laser shutter? It might be stuck closed. Some techs like to remove it.
      • ruben
        The New Guy
        • Oct 2012
        • 1204
        Just in case, do a memory clear on Printer Application. (You will need to redo the ACC for printer afterwards.)
        Go to Printer SP and print out a colour test pattern. If it is blank then you have a laser or TX problem, if only black is missing then you could have a shutter or PCU problem.
        • rich1106
          • Feb 2014
          • 21
          Thank you all for your reply!
          Originally posted by Max
          blank copy?
          Yes, Blank Copy
          I already changed the laser unit. and blank copy continuous
          I tried your suggestion. And I printed the test pattern And it is blank... I already changed the laser unit.
          Again, thanks for your help. Another suggestion?
          • skynetto
            • Sep 2012
            • 257
            Still in laser section: does the shutter motor works? check 2914-007 if it is set to NO.
            • PA3040
              • Jun 2014
              • 171
              Stop the machine while on copying and check the ITB and Four drum latest the image is developed on
              • godwin2017
                • Apr 2017
                • 2
                Please have you considered replacing the BICU board? Anyways I'm also facing same situation here. Blank copy everything about the machine is ok but still I'm facing the blank copy issue. Any help would be appreciated. Thanks!!
                • Polarbear
                  • Feb 2012
                  • 1070
                  +1
                  This is the only logical way to start troubleshooting. For all you know, it tore the ITB belt right off the frame (have seen this before) and the machine will sit pretty and say nothing.
                  Press the GREEN button!!
