Ricoh FW-870
  • copyplus
    • Jul 2009
    • 100
    Re: Ricoh FW-870
    Does anyone know the substitute of M25JZ51 thyristor. thanks
    • Polarbear
      • Feb 2012
      • 1070
      Re: Ricoh FW-870
      Seems the equivalents have an "S" in front, made by Toshiba
      see here: M25JZ51 ... - Datasheet Search Engine Download
      Hope this helps.
      It is also called a "triac" by some suppliers.
      Press the GREEN button!!
      • copyplus
        • Jul 2009
        • 100
        Re: Ricoh FW-870
        Can you please check my diagram that I sent earlier and let me know if the triac is good by looking at my figures. I will really appreciate it. thanks
        • copyplus
          • Jul 2009
          • 100
          #19
          Re: Ricoh FW-870
          M25JZ51.pdf
          Here is the diagram
          • PA3040
            • Jun 2014
            • 171
            #20
            Re: Ricoh FW-870
            Better way, if you do not have electronics knowledge. Give it to TV repair shop to check the thyristor and get the advice
            • copyplus
              • Jul 2009
              • 100
              #21
              Re: Ricoh FW-870
              I got the power supply fixed. It printed one copy and now its showing front door open error. I have tried everything I could but that error does not go away. Any useful suggestions? thanks
                • 37515
                #22
                Re: Ricoh FW-870
                One of the fuses on the power supply. Check the service manual and Goose's Guide.
                • jdzr
                  • 125
                  #23
                  Re: Ricoh FW-870
                  I think you will find the safety switch wiring does go through the ac power supply. You can also unplug the connections at the board and check the entire circuit from there.
                  (sounds like you still have a problem at the ac board)
