windows 8 slow printing even ps card installed
  • saa
    • Apr 2014
    • 10
    [Misc] windows 8 slow printing even ps card installed
    windows 8 very slow printing even post script card installed.
    1. windows 7 perfectly ok.
    2. used all driver from ricoh site ps driver / plc 6 / plc 5c. All slow printing.
    3. I don't think any firmware updation issue is.
    4. As problem is with multiple printer mpc 2501 / mpc 3003 / mpc 3002 etc etc
    Looking for solution.
    thanks
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: windows 8 slow printing even ps card installed
    Microsoft Support
    I'd be contacting Microsoft. Windows 8 is Satan's operating system.
    Hit it.
      • 37556
      If you have JAVA installed and they are not using it, disable it.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Just remember... "8 ain't so great", and you'll be fine.
        • Iowatech
          Not a service manager
          • 3930
          Just for grins and if time permits, you might see if a Windows 7 print driver would work better.
          Then again, I've only seen that work once, so maybe not.
          I miss RPCS.
          • sandmanmac
            • 3983
            I miss RPCS.
            Actually, the drivers from one OS to the other are identical. Just compare the versions and filesizes. Only differences are 32 bit Vs. 64 bit systems. I'm not sure why Ricoh bothers to list them all seperately - even for Win 8 and 8.1.
              • 37556
              I think it is because Ricoh's download page is available to end users. Many users, if they do not see their exact Windows version listed, would not know what to download.
              • techsass
                • Dec 2010
                • 248
                Just a silly thought, but are you sure it's using the driver you're trying to install and not Window's built in driver?
                I've run into this on color boxes before. You go thru the whole have disk method, even trying the different radio buttons and it still loads the Windows driver. Looks right, but errors out when you try to change the defaults to B&W, etc.
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  Assuming the machine has postscript (you did say you tried the ps driver), try LPRing a troublesome PDF file to the machine. It will print without using a driver.
                  From a command prompt, type: LPR -S <ip of printer> - P lp c:\filename.pdf
                  The S and P are case sensitive.
                  This will tell you if it is a driver issue or not.
