MP C2500: Scanner is currently in use by another user
  • lfbb
    • Jun 2014
    • 8
    [Error Code] MP C2500: Scanner is currently in use by another user
    Hi all,
    When I try to scan a document with Adobe Acrobat I get the error message on the title of this post and I can't scan. If I uninstall the Twain driver (Ver.4.19.04) and reinstall it I can scan again. It's very annoying having to uninstall/install the driver every time the error occurs. I'm on Windows 7 Professional x64 SP1.
    How can I solve this?
    Thanks in advance.
    • 37556
    Re: MP C2500: Scanner is currently in use by another user
    Does this message appear in Adobe or is it on the screen of the MP C2500?
    • lfbb
      • Jun 2014
      • 8
      It appears on Adobe. I took a screenshot, the driver is in portuguese, the english version won't install.
      • lfbb
        • Jun 2014
        • 8
        In the custom scan dialog box of Adobe my webcam appears as a scanner. Could it be related to this?
        • ruben
          The New Guy
          • Oct 2012
          • 1203
          Why for the love of all that is Sciencey, are you using TWAIN? Just setup SMB scanning, takes 2 seconds on Windows 7.
          • lfbb
            • Jun 2014
            • 8
            Sorry, ruben, but what is SMB scanning and how do I setup it?
            I tried to scan in safe mode and it works with no errors, definitely it's a driver related thing.
            • rthonpm
              • Aug 2007
              • 2859
              Aficio MP C2000/C2500/C3000 download page
              Here are the manuals for the device, which will explain everything.
              • ruben
                The New Guy
                • Oct 2012
                • 1203
                Note: This only works if you are using a network cable and not a USB cable to the copier.
                Create a new folder somewhere, right click, properties, sharing, advanced sharing, tick share this folder, give it an easy to remember share name (like: scans), permissions, tick full control to everyone. This folder is now shared over SMB, the network path under properties is what you will need to enter on the copier.
                On copier:
                Go to the scanner button, folder, manual entry, type in the network path, enter your username and password. Do a test scan, if it doesn't go through, then the firmware of the copier is not up to date or you have an anti-virus or firewall blocking it. If it does go through press prg dest and enter a name and key display; to save for future use.
                If you don't know your username you can find it by opening computer, c: or whatever your OS drive is, and users. The folder that isn't default or public or something.NET is your username. You can also do CMD -> set user.
                File sharing will need to be turned on for this to work, thankfully it is on as default under most Windows 7 type OSs.
                • lfbb
                  • Jun 2014
                  • 8
                  Thanks, ruben, I will try that.
                    • 37556
                    In most instances I would agree with you. I was thinking about that this morning but decided I wanted to know where the message was. I do have a couple of legal and medical customers whose software require that they used the software's built-in scanning function thus requiring either TWAIN or WIA.
                    • lfbb
                      • Jun 2014
                      • 8
                      I'm trying to set up the SMB scanning in the Web image monitor. I have read several tutorials but I still don't know what to put in the login user name. What name should I use?
                      Thanks in advance.
                      • ruben
                        The New Guy
                        • Oct 2012
                        • 1203
                        Thanks in advance.
                        Recheck my post again, I give you two different ways. If you Windows Key + R, "CMD", "set user". This will be the quickest way.
                        • lfbb
                          • Jun 2014
                          • 8
                          I'm trying scan to email but I don't know what the user code is in the address book. If I enter any name it gives me an error. Can you help me?
                          Thanks in advance.
                          • ruben
                            The New Guy
                            • Oct 2012
                            • 1203
                            User codes are for recording copier usages, ignore it. Please read the user manual, we aren't your tech support.
                            • lfbb
                              • Jun 2014
                              • 8
                              I finally found what was wrong with the TWAIN driver, it had a conflict with Kaspersky anti-virus. I turn it off and I can scan. Thanks anyway for all the help.
