How to disabel the copy function?
  • gadrams
    • Jul 2025
    I have a Ricoh MP5500; is there any way to disable the copy function from this printer. In my office we only use the printer and scanner function. Can disable the copy function be possible?
  • nmfaxman
    • 1702
    Enable user codes for copying but don't enter any code for users.
    • gadrams
      How do I go by doing this? Thanks
      • iMind
        Vacuum Cleaning Expert
        • Mar 2008
        • 1116
        there is a way, enter service mode 5 118 enable (copy disabling) Japan only but it works, but you must be a tech to enter service mode.
        • gadrams
          Not good news but thanks...
          • schooltech
            School District Tech
            • Jun 2008
            • 504
            I agree with faxman, just put in user codes for the copying. That would be, from a user standpoint, the easiest thing to do. Then, you have control over who can make copies (if they ever need to) and can keep an eye on copy volume.
            If it is done from service mode, there will be no way to use the copying feature. At least with the codes, it will restrict all but those with rights.
            Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
            • gadrams
              Im not a service tech, any tips would be helpfull guys. thanks
              • iMind
                • Mar 2008
                • 1116
                Try this:
                Press the [User Tools/Counter] key
                Touch [System Settings]
                Touch the [Key Operator Tools] tab then touch [Next] to view the second page of this menu
                Touch the [Address Book Management] key then touch the user key whose User Code that you want to change
                Go to Step 7 if you want to change Name and Title details of the user
                Go to Step 8 if you just want to change a user's User Code
                View the displayed Program/Change Address Book menu and :
                touch [Change] and enter a new User (Destination) Name from the display keypad (touch [OK] to finish)
                the User (Destination) Name box will now show the new name
                do the same to change the name of the title that you want to appear on the Key Display (if you decide to skip this step, the User (Destination) Name will be used by default)
                select the Title Key - your user/destination will be stored under the selected title letter or number
                Touch [User Code] if you have enabled User Code Management and want to assign a different 8-digit code that the new user must enter before operating the machine:
                touch [Change]
                enter a new 8-digit code from the blue numeric keypad then touch the Hash key
                touch to select or de-select the functions whose access that you want to restrict with the User Code
                Touch [OK] then touch [Exit]
                Press the [User Tools/Counter] key to exit from the User Tools menu
                If displayed, touch [Exit] at the dialog box which alerts you that the Destination List
                • gadrams
                  Thank you iMind
