Ricoh mp 9000
  • khaled_abosere3@yahoo.com
    Head technical support
    • Mar 2012
    • 171
    [Jamming] Ricoh mp 9000
    Our problem concentrate that suddenly when we making any copy paper stopped at entry of fusing unitwe made output check on fusing motor found it not working there is no any service code appear to confirm that fusing motor is defective or any thing else.With my greetings.
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: Ricoh mp 9000
    isolate first if what sensor is detecting the jammed paper. check logs.
    Nobody is perfect..
    • vargue
      • Oct 2011
      • 404
      Re: Ricoh mp 9000
      revealed your skills where paper jam. watch what make jam. fingers/ fuser gate / etc sensor then jam with first paper or with heavy works.some thread must be watched
      • imaginemoko
        unTrusted Tech
        • Jan 2008
        • 289
        Re: Ricoh mp 9000
        if it happes that the machine give Jam 21... and not even a single paper is not passing it tends to be the fusing drive motor is the problem. basically the motor will run when you make output check... the problem there is that the white gear inside that motor has loose its grip to the shaft that why it does'nt drive... anyhow Good Luck Sadiq... Salam.
        fix the customer first then fix the machine... its simple and makes life more easy.
        • Coptech
          worker drone
          • 460
          Re: Ricoh mp 9000
          HR Gear
            • Mar 2012
            • 171
            Re: Ricoh mp 9000
            My dear sweet as i wrote that when making output check the motor does not drive.
              • 37558
              Re: Ricoh mp 9000
              Is it that the motor does not run or that the hot roller does not turn? If the latter, see what see what coptech said. HR = hot roller.
              • imaginemoko
                unTrusted Tech
                • Jan 2008
                • 289
                Re: Ricoh mp 9000
                have we try to check physically this motor? or even test it on other machine? hot roller gear is metal so it wont worn out that easily. sometimes the motor that drive the hot roller does come back to engage it has a spring and in time it accumulate rust.
                • Coptech
                  worker drone
                  • 460
                  Re: Ricoh mp 9000
                  Where are you seeing a metal HR gear on an MP9000? They didn't use metal until they got to the D101 line. Am I wrong?
                    • Mar 2012
                    • 171
                    Re: Ricoh mp 9000
                    Both of them do not run if fusing motor or hot roller.
                    • Imprestik
                      • Aug 2012
                      • 297
                      Re: Ricoh mp 9000
                      Remove the fuser and run in output check the fuser motor by cheating the door switches
                      If the motor is turning I can bet you the drive motor is on a spring tension and the spring has got stuck in the frame causing the fuser not to drive or due to rust the spring and shaft are not releasing
                      Just add a touch of oil and manually push the shaft/spring in and out a couple of times until it feels free
                      If you find the fuser motor is not rotating with the fuser out of the device in output check, just order a new fuser drive motor
                      • imaginemoko
                        unTrusted Tech
                        • Jan 2008
                        • 289
                        Re: Ricoh mp 9000
                        Sir Aficio MP 9000. 90 copies per minute, Bellini C3, known to be Katana (B234). or maybe its me who's wrong... my apologies.
                        • Coptech
                          worker drone
                          • 460
                          Re: Ricoh mp 9000
                          You are not wrong. I stand corrected. The B234 is a metal gear machine. Go with the spring loaded drive theory or the motor itself, or drive board. The strategy of cheating the front door and watching the drive with the fusing drive selected in the output mode is a good one.
                          • redneckstylin
                            • Sep 2011
                            • 173
                            Re: Ricoh mp 9000
                            Spin the knob on fuser does your rollers turn if not head to back of fuser and you will find a broken gear of doom replace gear and you will be back up and running sipping on a cold beverage after
