How to hack MFP / MFD RTOS ( Operating System )
  • PA3040
    • Jun 2014
    • 171
    Dear All,
    Does any one have experience to communicate with MFP or MFD operating system
    Normally we can do this with SDK development kit that we must buy from OEM
    If we can access os then we can connect machine with custom developed embedded systems
    Does any one have this type of experience with Ricoh machine
    I know Ricoh recently officially launched smart embedded connectivity via WiFi
    But I am asking just like H.......a.......c........k.........hjhkhk
    Please do not misunderstand since it is called revers engineering
  • skynetto
    • Sep 2012
    • 257
    Re: How to hack MFP / MFD RTOS ( Operating System )
    Good luck with Ricoh RSA firmware encrypted system.
    • teebee1234
      • Jul 2008
      • 1670
      I don't know of any way to do it (not that it can't be done). Here is a link to the developer site, which has 4 tiers of membership (not sure if it is of any help but you can check it out).
      Ricoh RIDP
      • Eric1968
        • 2458
        Ricoh is using NetBSD on their machines. A very robust operating system. You may be able to write software for the machine, but in my 21 year career I never saw anyone "hacking" a Ricoh MFP and get to the source code level.
        • PA3040
          • Jun 2014
          • 171
          Ricoh RIDP
          Dear tee
          Thanks for the reply with link and I will check and update you
          • PA3040
            • Jun 2014
            • 171
            Yes, It is really hard to access entire OS. But we can develop embedded systems for fulfill our some requirements catching some signal from the chip level
            Actually my original post was asking about revers engineering of entire OS
            My current requirement is collect the copy count automated way without attending tech to the machine
            I mean, we have to develop embedded system pick the copy count from the machine then we can send it to server via GSM modem
            Any one have idea
            Thanks in advance
            • Eric1968
              • 2458
              You don't have to develop anything, you can use @Remote or Kyofleetmanager to do this. These solutions also keep track of toner levels and various other things, so forget about reverse engineering the source code. I'm not saying that it's not possible, but I think it's a waste of time.
              • skynetto
                • Sep 2012
                • 257
                If you cant use @Remote you can still develop a C++/C# program to work with SNMP data. On Ricoh RiDP (upon registration) you can find the Private MIB specification for all Ricoh machines. With these data you can gather all the information the MFP sends thru SNMP. Collectiong these data on a remote server or sending a mail from a client PC to your mail its just then a piece of cake.
                • PA3040
                  • Jun 2014
                  • 171
                  Those are valuable details and information
                  But unfortunately majority of our machines are non connectivity machines. Therefore we have to develop wireless connection to connect mobile Network, That is the only way I think we have to gather the information's
                  in our case all tech's must collect the copy counts of each machines from 25th to 30 each months for Invoice
                  any advice
                  • PA3040
                    • Jun 2014
                    • 171
                    majority of our machines are only USB and not connected to PC.
                    My experiment models are Ricoh kir c3 and kir c4
                    Both models FRAM are communicating with BICU using SPI protocol, I can develop the embedded system to communicate with SPI to collect copy volume, apart from that not that much hard
                    Do you have any idea in this regard
                    • PA3040
                      • Jun 2014
                      • 171
                      Still I could not find abbreviation for RSA......sorry
                      • Eric1968
                        • 2458
                        any advice
                        You're talking about Ricoh MFP's. MFP means that it's a multifunctional machine. So you're saying that all of these MFP's are not connected to a network? So the customer buys a machine (let's say an MP C3001, which can do network scanning, printing, etc.) and uses this machine without connecting it to the network, which leaves only the copy function available????
                        • PA3040
                          • Jun 2014
                          • 171
                          [QUOTE=Eric1968;424186]You're talking about Ricoh MFP's. MFP means that it's a multifunctional machine. So you're saying that all of these MFP's are not connected to a network? So the customer buys a machine (let's say an MP C3001, which can do network scanning, printing, etc.) and uses this machine without connecting it to
                          Our models are MP2000 and MP2001L AA versions those are MFP's but No NIC
                          Sorry if you got misunderstood by my wrong explained
                          • Eric1968
                            • 2458
                            [QUOTE=PA3040;424192]
                            Our models are MP2000 and MP2001L AA versions this are MFP's but No NIC
                            Sorry if you get misunderstood by my wrong explained
                            No problem.
                            If the machines are not networked you've got a challenge!
                            • rthonpm
                              • Aug 2007
                              • 2859
                              To get anywhere on the heavily modified version of BSD Ricoh is using, you'd need super user access, which you won't get. If you were, you'd still have the issue of getting any kind of connection to a mobile network. With old school offline machines, your easiest way of getting metres is going to be the equally old school way of getting faxed metre sheets, or a manual collection once a month.
