Lanier LD630C with error sc899
  • axyun
    • Aug 2007
    • 1323
    Customer called this afternoon with error SC899 on LD630c. I understand that this may be a print job that is causing issues and that cancelling job and if long one, breaking it up into smaller segments for printing. Please advise . Frank/ActionPhotocopy
    • 37513
    Re: Lanier LD630C with error sc899
    It usually is a caused by a print job from a web page with IE 8 or 9. Usually is caused by scrolling text or a moving .gif on the page. If this is the case, tell the customer to try print preview first which flattens the file(no moving anything) and then print from the preview. Another thing to try is to use PrimoPDF, NitroPDF or some other print to PDF software, then print the PDF file.
    • axyun
      • Aug 2007
      • 1323
      Thank you Tim.
      • slybot
        • Sep 2010
        • 165
        if your able to get hold of the firmware upgrade it to the latest versions
        • craigchowles
          Apparently acrobat reader XI plug in for internet explorer is causing an issue as well. It is not closing off the print file so the printer CPU doesn't know what to do with it and ends up stalling. Try downgrading to acrobat X.
          • axyun
            • Aug 2007
            • 1323
            Thank you Craig.
            • ptrflrs
              Glorified Parts Swapper
              • Dec 2010
              • 192
              just to throw this out there have confirmed Groupon voucher printing and certain maps will also cause sc899. Many ricoh machines having sc899 with Web page prints. I was able once on a c300 to update firmware with file still in print queue and causing sc 899 to print without error after firmware. It was a Web page print of a line drawing for kids crayon coloring.
              jesus loves you! (everyone else thinks you're an assh*le)
              street cred: CompTIA A+ & Network+ Certified; Konica Minolta Gold Seal x2,
              Konica Minolta Outward ASSociate, Ricoh, Sharp, Lexmark trained
              • axyun
                • Aug 2007
                • 1323
                Thanks for additional info ptrflrs. Frank
