Reco oficio Gastetner 3222 poor copy result
  • shop14
    • May 2025
    plz help me.. my copier not working very good now.. small words our Micro copy prints are not good.. see the both pics ..one is orgnal and the other one is copy from orgnl and the copy result is very bad .. i dnt know where the problem is.. plz guid me how to solve this problem
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Reco oficio Gastetner 3222 poor copy result
    Just like what you posted on you other username. Hire a qualified engineer.
    We are not your tech support.
      • 37062
      Better yet, replace the dinosaur.
      • shop14
        sorry.. who is hire?? i dnt know
          • 37062
          ruben said a qualified engineer. That is someone trained on the equipment who works for an authorized service center and has available all the manuals, supplies and parts needed.
          • Iowatech
            Not a service manager
            • 3930
            Sorry, I have to ask - the original in your picture is pretty bad. Why do you expect the copies of that to look good?
            As far as I can tell the picture of the copy is exactly what copies should look like from that original.
            • shop14
              yah original is not too good but i am just showing you sample .. but when i copy from good writing page then also this problem.. copy is not clean .. too bad words are not read clearly .. just small words not large
              • Iowatech
                • 3930
                Then try sharing a better example. It is a good way to get more accurate advice on a more timely basis.
                We can't see your machine and what it is doing after all.
                On a lighter note, there is a small chance that your toner is bad, or you don't have the machine's paper supply set up correctly. You should probably check that.
