Ricoh Aficio 2015, pcu
  • Hansoon
    • Sep 2007
    • 3385
    Remote customer out of my territory complains that copies has smears on it. Before I go there I think I should get a PCU # B1212200. I would like to know if with that number I will get a complete PCU with developer and drum or must the developer be purchased separately. Since I am, regarding Ricoh, a noob (you guessed it already) I would like to know what set up procedure is necessary for a Aficio 2015 to install a new PCU.
    Thanks in advance!
    Hans
    • 37491
    Re: Ricoh Aficio 2015, pcu
    I believe that it is only the PCU case assembly. In the latest parts catalog the developer is pictured outside the dash line box indicating it is not included. Also, there are different part numbers for the developer depending on location, B1219640 for Asia and B1219645 for north America and Europe. I am not certain about the drum. I usually order the PM kit PMB12160K, drum B0399510, and developer. Fusing PM kit is PMB121120K.
    • Eric1968
      • 2458
      Complete PCU comes without developer (Type 28), but it can be expensive. Rebuilding the PCU takes about 20-30 minutes, and it saves you some money.
      After replacing the complete PCU with developer or after rebuilding the PCU run SP2-214 to initialize the developer.
      • Hansoon
        • Sep 2007
        • 3385
        Thanks guys.
        Eric, wat is het part # voor de developer in Europa?
        Groeten.
        Hans
        • skynetto
          • Sep 2012
          • 257
          B121-9640
          B121-9645
          DD11BLK
          K162
          Type 28
          Are all the same. Just make sure it has Type 28 Developer written on the box.
          • Hansoon
            • Sep 2007
            • 3385
            Molte grazie.
            Hans
            • skynetto
              • Sep 2012
              • 257
              Di nulla
              • Eric1968
                • 2458
                Originally posted by Hansoon
                Thanks guys.
                Groeten.
                Hans
                B121 9640
