ricoh c6501 sp
  • BigHenry
    ricoh c6501 sp
    I have a 6501 Ricoh that I bought used and I got a error for bad hard drives. I have replaced the 160GB drives with 500GB and since I am a computer guy I am assuming there has to be a process to format these drives. but can not find a manual for the 6501 but in the 6502 it does not give the steps just reads to call a service provider. So any help would be great.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: ricoh c6501 sp
    You have to low level format on a PC first, then go into SP5-832-001. Manuals are only available to engineers, or from third parties for a price.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Re: ricoh c6501 sp
      contact paul@justmanuals.com
      Mystic Crystal Revelations
      • Iowatech
        Not a service manager
        • 3930
        Re: ricoh c6501 sp
        For the time being you might find it easier just to go here:
        Ricoh Color Copier [D081, D082] MP-C6501SP, MP-C7501SP Parts & Service Manual - $14.77 : Just Manuals, The Internet's largest selection of manuals ~ Instant Downloads
        • turbojetboy
          • Aug 2009
          • 279
          Re: ricoh c6501 sp
          I have to say....the HDD's are only just the tip of the iceberg when it comes to the problems you are going to see with this model!
            • 36910
            Re: ricoh c6501 sp
            I assume that you are referring to the frequent toner scattering.
            • ewizzy
              Dirty toner monkey
              • Feb 2014
              • 55
              Re: ricoh c6501 sp
              I did the RTB for toner scattering, amazingly, it works. I was gobsmacked
              • redneckstylin
                • Sep 2011
                • 173
                Re: ricoh c6501 sp
                my RTB pointed to a 20lbs hammer for this model
                • ewizzy
                  Dirty toner monkey
                  • Feb 2014
                  • 55
                  Re: ricoh c6501 sp
                  I had a metric RTB, Told me to use a 9.07185Kgs hammer.... will it work the same in metric
                  • johnyb
                    • Feb 2011
                    • 167
                      • 36910
                      Re: ricoh c6501 sp
                      I had two of them in my territory, same customer. One worked fine other than PM calls. The other worked fine for a while, then started blowing toner. Followed instructions in bulletins 013, 017, 035 and 040. Machine worked fine until they replaced both of them and two B/W machines (an Savin 8075 and a MP 9002) with 4 MP C 6502s.
