Mpc3001 ps option swap
  • mrfuser
    • 1617
    Anyone know how to turn off error message when you take a ps option out of one mpc3001 and put it in another?
    Kelly
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Mpc3001 ps option swap
    What error message?
    • mrfuser
      • 1617
      Says this ps chip was already installed on another machine
        • 37502
        Remove the PS SC card.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          Not sure, but I think it has to be properly uninstalled from the original machine. Not just "yanked".
          if I recall, the host MFP writes it's serial number to the card. No way to remove it, AFAIK.
            • 37502
            The PostScript SD option for the MP C3001 is a Type 5501. If it is any other type, you have the wrong SD card. If it were a MP C3002, I would be inclined to say that the application had been moved to another card using SP5873 and had not been moved back. The other possibility is that someone has attempted to access the card with a PC.
            • mrfuser
              • 1617
              So we must "uninstall" the software back to the ps card before removing it? It is mpc3001
                • 37502
                If it was moved. Moving places the application on the other card. Only an identifier is left on the original which allows the card to be identified when moving the application back. An SD card application can be used only on one machine at a time. Software copywrite protection laws.
                • mrfuser
                  • 1617
                  The card only was moved and we only need it on one unit. Must it be uninstalled via service mode before removing from original machine before removing it and putting it in other unit?
                    • 37502
                    Yes
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      There, my friends, is why you NEVER buy a used PostScript SD card.
                      Far too common a mistake. We've even had our own warehouse send us used cards that were this way.(been a long time, but not forgotten.)
                      • mrfuser
                        • 1617
                        Hello all,
                        Well we tried the ps driver and all works fine as if the PS is truly installed as original. The ONLY hitch here is the annoying little message on bottom left screen saying the software has already been installed elsewhere. Other than that it works perfect.
                        Any ideas how to disable those messages that pop up on the screen?
                        Kelly
                        • Richariri
                          • Dec 2013
                          • 163
                          Going for a quick highjack here...
                          I've got a HDD encryption unit fitted on a machine we've just had delivered and i want to know if I can remove the SD card and module and fit them to another machine of the same model?
                          Do I have to do an uninstall like the PostScript card? Because it's an encryption unit, am I likely to hit any security issues?
                          Thanks' in Advances
                            • 37502
                            Thanks' in Advances
                            If the HDD encryption has already been initialized on one machine, you can not remove the SD card and use it elsewhere. Ricoh has set it to where once in use on one machine, a SD card cannot be removed and put in another machine. If there is an uninstall procedure in the service manual, then you can uninstall and move to the other machine.
                            • Richariri
                              • Dec 2013
                              • 163
                              Ok thanks Slim,
                              To be honest I just wanted to remove it from the machine... what about the JAVA embedded software? can I remove that?
                              As for the postscript option in this thread, what SP mode would I need to execute in order for it to be useable in another MFP?
