MPC3003 Home Screen Logo
  • copier tech
    • 8132
    Quick question, I tried to add a customised logo on the home screen for a customer, I followed the instructions exactly in the official guide (attached below) but each time I tried it failed, got a message saying incorrect format something like that, basically I get the same message with no SD card inserted. I created a folder called "custom_uiimage" on my SD card & in that folder was my logo named "insert.jpg" the size was 324 x 66 as the MPC3003 has the 9" screen? I can print this logo fine so the machine can see my SD card!
    Like I say I followed the guide exactly! any ideas please!? am I missing something!?
    Ricoh_Add_Logo_HomeScreen_ControlPanel.pdf
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: MPC3003 Home Screen Logo
    It's one thing to call the file "insert.jpg" but it actually has to be a jpg file. Also I never load the image from a sd card, I load it from the WIM.
    Mystic Crystal Revelations
    • copier tech
      • 8132
      Hi, well yes the image is definitely a JPEG, so I didn't actually name it image".jpg"
      I will try the WIM but thought it would be easier to do it at the MFD.
      • mikadonovan
        • May 2008
        • 2931
        I have only done this through the WIM. Once I found out the size had to be EXACT all was good to go.
        NEVER ASSUME ANYTHING
        • fbkhan3
          • May 2012
          • 421
          (Custom_uiimage) is wrong.The folder structure should be custom_ui / image/ and name the file insert.jpg. and yes the file size should be the exact as it is explained in the guide. and it's very easy through WIM as mentioned earlier. hope that helps
          • copier tech
            • 8132
            Thanks for the info, just found this link that's is a bit more helpful.
            Displaying the Image on the [Home] Screen Using the User Tools
            • fbkhan3
              • May 2012
              • 421
              Thanks for the info, so do I create a folder on my SD card as "custom_ui" & in that folder put my logo named "insert" ?????
              Create folder named "custom_ui" then in this folder create another folder called ''Image'' then put the logo named ''Insert.jpg'' in there.
              • SargeNZ
                • May 2012
                • 263
                Just a heads up, I have found that some applications do not work when creating the home screen image. When resizing an image with 'IRfanview' it would not work, but opening and resaving the image in mspaint would suddenly make it start working. Weird.
                • Richariri
                  • Dec 2013
                  • 163
                  Yer, I had same issue.
                  We're putting our logo and service number on all new machines now and when I first created the image in GIMP2 I saved as a .jpg and it just wouldn't work.
                  Opened the image in paint, saved as .jpg again and basically created a duplicate using paint. Worked first time.
                  crazzzy!
